wfopen(type=odbc): data being unstacked as string
maragloria
Postby maragloria » Tue Jun 01, 2021 12:49 pm
I'm trying to unstack a dataset from SQL, but the data remains a string (instead of a "time series") when I use the unstack command. Could you please take a look on my code?
I've attached the workfile and the code follows here:
wfopen(type=odbc, timeout=400, wf=temp) zap_beta {%QUERY} @id serie_name @date(start_date) @destid serie_name @date @smpl @all pageunstack(page=Unstackt,namepat =*_?) serie_name start_date @ datavalue_converted
Many thanks,
Mara
temp_A.wf1
(13.23 MiB) Downloaded 962 times
Re: wfopen(type=odbc): data being unstacked as string
Postby EViews Gareth » Tue Jun 01, 2021 1:26 pm
Simple solution is to use @val to convert the alpha series into a numerical series prior to unstacking.
maragloria
Postby maragloria » Tue Jun 08, 2021 6:46 am
Thank you Gareth! It works.
maragloria
Postby maragloria » Mon Nov 15, 2021 9:56 am
Hello Gareth,
I got a follow-up question: how can I add metadata to the series' fields "display name" and "description" when the data is unstacked? The metadata are available in the workfile as string (stacked).
Please find the code I'm working with below.
Many thanks,
Mara
%QUERY = " SELECT * FROM [ZAP_CG].[ollim].[haver_series_traitées] where frequency='"Q"' order by [serie_name], start_date" wfopen(type=odbc, timeout=400) zap_cg {%QUERY} @id serie_name @date(start_date) @destid serie_name @date @smpl @all series datavalue = @val(datavalue_converted) 'convert alpha series into time series pageunstack(page="Q",namepat =*_?) serie_name start_date @ datavalue pagestruct(bal=se) @date(start_date) rename datavalue_* *
Postby EViews Gareth » Mon Nov 15, 2021 10:42 am
You'll just have to use the commands to set them.
maragloria
Postby maragloria » Thu Nov 18, 2021 11:12 am
Hello Gareth,
Thanks for your reply. I'm a bit loss on how to use setattr on stacked data. Could you take a look at my file and tell me how for instance to add the alpha values "target_desc" to the attribute "display name" for each country series?
The series id are in "serie_name" and the data in "datavalue".
Many thanks,
Mara
zap_cg.zip
(3.19 MiB) Downloaded 1040 times
Postby EViews Gareth » Thu Nov 18, 2021 11:31 am
I'm not sure what you're asking.
maragloria
Postby maragloria » Thu Nov 18, 2021 4:01 pm
Hello Gareth,
I'll try to make it more clear.
In the page Zap_cg I got stacked qtly data in "datavalue".
I'm unstacking into a new q page (not shown in the file I've sent), using "serie_name" as the id:
pageunstack(page=q,namepat =*_?) serie_name start_date @ datavalue
In the page Zap_cg, there're also a few alpha objects storing some metadata. I would like to add some of these metadata as attributes to the unstacked time series in the new page q.
So, for instance, the first line in the stacked "datavalue" is BIS_CRDGGOV_ARG - 92Q4. This turns into a time series called BIS_CRDGGOV_ARG running from 92Q4 to 21Q1 when unstacked. I would like to add "Argentina: Adjusted Credit to the General Government [Nom Val] (EOP, % of GDP)" found in the alpha object haver_desc as the attribute Description to BIS_CRDGGOV_ARG (the resulting unstacked time series in the new page q). I couldn't manage to do it.
Postby EViews Gareth » Fri Nov 19, 2021 7:41 pm
Ah, for that you can use the handy importattr command.
pageunstack(page=q,namepat =*_?) serie_name start_date @ datavalue d datavalue rename datavalue_* * importattr(name=serie_name) zap_cg @keep haver_desc %serlist = @wlookup("*", "series") for %j {%serlist} %newdesc = {%j}.@attr("haver_desc") {%j}.setattr("Description") {%newdesc} next
maragloria
Postby maragloria » Mon Nov 22, 2021 10:57 am
Wow, awesome! Very handy indeed! Thanks very much for the help.
