Creating subgroups
Posted: Sun May 30, 2021 8:31 am
by AnaAL
Hi, i'm new to eviews and i need some help. My teacher asked me to create subgroups to be able to do a wilcoxon test, but I've trying to create the subgroups by changing the sample, using the smpl command or changing in the "sample button", but when I try to create another subgroup, by changing the sample again i loose the first one, because it changes to the new sample information.
Is there a better way to create subgroups or is there a way to save them, so the data doesn't change when I create a new one?
Thank you for your help!
Re: Creating subgroups
Posted: Sun May 30, 2021 8:56 am
You can create sample objects that save the observations you want to work with. Then whenever you do some analysis you can select the sample you wish to use.
