Estimating panel ARDL/PMG: How to interpret trend specifications.
Posted: Fri May 21, 2021 7:20 am
The Eviews manual says that "This model takes the cointegration form of the simple ARDL model and adapts it for a panel setting by allowing
the intercepts, short-run coefficients and cointegrating terms to differ across cross-sections". It sounds like the intercepts here refers to the long-run intercepts, and in the dropdown trend sepcification menu it says "constant(level)", but - here is the odd thing - constant and trend appear in the short-run equation in the estimation results. How should I interpret this???
Furthermore, when translating the long-run trend specifications (restricted constant, constant and restricted trend) from a VECM/ARDL setting, what are the equivalent cases/specifications used in panel ARDL/PMG?
Best,
Lars
Best,
Lars
