How to use fracdiff EViews add-in to perform the fractional Dickey-Fuller test
Posted: Sat May 08, 2021 8:54 am
by bensalma
' With EViews 9 'The objective of this program is to find the upper and the lower bound of the fractional integration parameter of an ARFIMA(0,d,0) 'by using a sequential standard dickey-Fuller test, based on the usuels tabulated values. 'This program is not flexible enough to use it in any situation (for example for d>=1). I am not an expert in programming. 'But this program shows how efficient the sequential procedure is. 'In this program we simulate a process ARFIMA(0,d,0) (For example d=0.6). 'Then, we assume that (d) is unknown and we try to find an upper and lower bound for (d) by using a sequential procedure of the Dickey-Fuller test. 'Try to perform the program several time for a fixed value of d. 'Change the value of (d) (for example d=0.3, d=0.4, d=0.5) and perfom the program several time for each value. create u 600 '--------------------------------------------------------- 'Simulation of an ARFIMA(0,d,0) with d=0.6 '--------------------------------------------------------- genr e=nrnd e.fracdiff(d=-0.6,) rename e_diff x genr y=x-@mean(x) vector (10) Accept_Reject_H0 '------------------------------------------------------------- ' Set of sequential values of (d0,i) and (d0,i-1) '------------------------------------------------------------- for !i=1 to 10 !d0=0.1*!i !d=-1+0.1*!i '------------------------------------------ 'Compute xi(t)=(1-L)^(d0,i-1)y(t) '------------------------------------------ y.fracdiff(d=!d, ) rename y_diff x!i '------------------------------------------------------------------------------------ 'Testing the null H0:d>=d0,i by means the t-stat of c(1) 'coefficient in the model (1-L)^(d0,i)y(t)=c(1)*(1-L)^(d0,i-1)y(t-1) '------------------------------------------------------------------------------------ equation eq!i.ls d(x!i) x!i(-1) if eq!i.@tstat(1)>-1.94 then Accept_Reject_H0(!i)=1 else Accept_Reject_H0(!i)=0 endif delete x!i next '-------------------------------------------------------- 'Find the lower and the upper bound of d '-------------------------------------------------------- for !i= 1 to 9 if Accept_Reject_H0(!i)=1 and Accept_Reject_H0(!i+1)=0 then scalar Lower_bound_of_d=0.1*!i scalar Upper_bound_of_d=0.1*(!i+1) endif next '-------------------------------- ' display results in table '-------------------------------- table tab1 setcolwidth(tab1,1,20) setcolwidth(tab1,4,20) tab1(1,1)="Table 1" tab1(2,1)= "Sequentiel F-DF test," tab1(3,1)="on the nile series: " tab1(4,1)= " H0:d>=d0,i; i=1 to 10" tab1(4,2)=" " tab1(4,3)=" " tab1(4,4)=" " tab1(4,5)=" " setline(tab1,5) tab1(9,1) = "d0,i" tab1(9,2) = "d0,i-1" tab1(7,3)= "DFt" tab1(8,3)="=" tab1(9,3)="eq!i@tsat(1)" tab1(7,4)="DF" tab1(8,4)="distribution" tab1(9,4)="cv(5%)" 'critical value of the Dickey-Fuller distribution tab1(6,5)="Accept(=1)" tab1(7,5)="or" tab1(8,5)="Reject(=0)" tab1(9,5)="H0" setline(tab1,10) tab1(11,1) = "0.1" tab1(11,2) = "0.9" tab1(11,3) = eq1.@tstat(1) tab1(11,4)="-1.94" tab1(11,5)=Accept_Reject_H0(1) setline(tab1,12) tab1(13,1) = "0.2" tab1(13,2) = "0.8" tab1(13,3) = eq2.@tstat(1) tab1(13,4)="-1.94" tab1(13,5)=Accept_Reject_H0(2) setline(tab1,14) tab1(15,1) = "0.3" tab1(15,2) = "0.7" tab1(15,3) = eq3.@tstat(1) tab1(15,4)="-1.94" tab1(15,5)=Accept_Reject_H0(3) setline(tab1,16) tab1(17,1) = "0.4" tab1(17,2) = "0.6" tab1(17,3) = eq4.@tstat(1) tab1(17,4)="-1.94" tab1(17,5)=Accept_Reject_H0(4) setline(tab1,18) tab1(19,1) = "0.5" tab1(19,2) = "0.5" tab1(19,3) = eq5.@tstat(1) tab1(19,4)="-1.94" tab1(19,5)=Accept_Reject_H0(5) setline(tab1,20) tab1(21,1) = "0.6" tab1(21,2) = "0.4" tab1(21,3) = eq6.@tstat(1) tab1(21,4)="-1.94" tab1(21,5)=Accept_Reject_H0(6) setline(tab1,22) tab1(23,1) = "0.7" tab1(23,2) = "0.3" tab1(23,3) = eq7.@tstat(1) tab1(23,4)="-1.94" tab1(23,5)=Accept_Reject_H0(7) setline(tab1,24) tab1(25,1) = "0.8" tab1(25,2) = "0.2" tab1(25,3) = eq8.@tstat(1) tab1(25,4)="-1.94" tab1(25,5)=Accept_Reject_H0(8) setline(tab1,26) tab1(27,1) = "0.9" tab1(27,2) = "0.1" tab1(27,3) = eq9.@tstat(1) tab1(27,4)="-1.94" tab1(27,5)=Accept_Reject_H0(9) setline(tab1,28) tab1(29,1) = "1" tab1(29,2) = "0" tab1(29,3) = eq10.@tstat(1) tab1(29,4)="-1.94" tab1(29,5)=Accept_Reject_H0(10) setline(tab1,30) tab1(2,4)="Lower bound of d="+@str(Lower_bound_of_d) tab1(3,4)="Upper bound of d="+@str(Upper_bound_of_d) tab1(4,4)=@str(Lower_bound_of_d)+"=<d<"+@str(Upper_bound_of_d) show tab1
sequential_fdf_test.prg
Program EViews to perform a sequential fractional Dickey-Fuller test on the demeaned Nile series
(6.05 KiB) Downloaded 19415 times
Hello Everyone
this is my first time participating in this forum. I want to share with EViews users how to use fracdiff Eviews add-in. I use fracdiff Eviews add-in, to perform the fractional Dickey-Fuller test. Here is the document link
https://mpra.ub.uni-muenchen.de/107445/ ... 107445.pdf
Re: How to use fracdiff EViews add-in to perform the fractional Dickey-Fuller test
Posted: Sat May 08, 2021 8:57 am
by bensalma
