Outcomes from Eviews commands in a program
Posted: Thu Apr 29, 2021 12:24 pm
I'm performing a system estimation of several equations using the SUR method with common structural breaks. In order to combine a system model with structural breaks I wrote a program file following methods by Baltagi et al (2015) and Bai and Perron (1998).
To get the standard deviation of the residuals of each equation k, I used the scalar value from System Data Members : @se(k).
However this value is not the same as the S.E. of regression provided at the bottom of Eviews output for the k'th equation after the estimation.
Furthermore, when I ask the covariance matrix of the residuals using @residcov(k,k), the square root of the k'th diagonal element is yet a different value than the two preceding ones.
Shouldn't these three functions give the same number ? If not what are their differences?
Thank you for your response
Best
Best
