SpecEval add-in: Add-in for time series model development
Posted: Thu Apr 15, 2021 5:32 am
by CrisisStudent
This is post for SpecEval add-in. The add-in is a multi-task add-in facilitating (time series) model development.
The add-in performs evaluation of (forecasting properties of) equation/VAR/identity object(s) and prepares report summarizing the results. It will return spool with tables and graphs that can be used for evaluation of (forecasting) performance of given equation, and/or compare forecasting performance across alternative specifications.
The add-in is aimed at facilitating iterative and interactive model development process, in which model developer improves the model based on information about the entertained specification(s). Consult separate document ‘SpecEval illustrated.pdf’ for illustration of model building process and for multiple examples of use of the add-in. (Associated data and programs are available on my GitHub site).
The add-in provides great deal of control to the user, who can adjust the procedures and outputs along many different dimensions. All options are documented in the add-in documentation, and most are illustrated in applications in separate document. Similarly, all the outputs and procedures are documented in dedicated document.
This is a live project; if you want to contribute feel free to reach out either here, or directly on my GitHub site.
Re: SpecEval add-in: Add-in for time series model development
Posted: Fri Oct 08, 2021 4:34 am
by CrisisStudent
New version (1.1) of the add-in has been released. It does not include any new functionality, but it implements several fixes or minor adjustments.
Posted: Wed Apr 30, 2025 8:07 am
by redversjones
Thanks, this is a really helpful tool. Could you clarify how the out-of-sample RMSE analysis works please? In the blog example there are OOS estimates for periods covering the original sample. Is there something similar to 'k-fold bagging' going on? i.e. re-estimate temporarily excluding a sub-sample and perform OOS tests on that sub-sample? Apologies if i've missed this in the documentation.
Posted: Thu May 01, 2025 2:57 am
by CrisisStudent
Thanks.
Briefly, OOS is really just using equation estiamted on sample 1,2,...t, to forecast data for t+1,t+2,...T, and then comparing the forecast with the actual values.
There are surely good illustrations online, but if you want my take, I am attaching chapter from my textbook.
