Panel Data Heteroskedasticity LR Test - Output Conflict
Posted: Mon Mar 08, 2021 9:41 am
Hi fellows,
for the attached raw data I have, I conducted Heteroskedasticity Test under Residual Diagnostics section.
You will also find attached outputs for cross-section and period tests. However, I am confused with the outputs. If I consider cross-section weight, I have to reject H0, which says that my data is heteroskedastic. On the other hand, if I proceed with period test, I do not have to reject H0, since it is >0.05 and thus, my data does not suffer from heteroskedasticity and which is the desired case.
How should I read the output? Does my data suffer from heteroskedasticity or not?
Any help will be appreciated!
Thanks,
Ayca
Thanks,
Ayca
