VECM model!
Posted: Sat Mar 27, 2010 7:49 am
Hi guys,
URGENTLY!!!
I would like to ask about 2 questions on the error correction model:
1) I am analyzing inflation determinants, first long-run in money and labor markets separetely using Johansen cointegration test, and second VECM model by running it in so-called Dynamic OLS (my understanding is simple OLS with lags of explanatory variables).
Within the first framework, i.e., cointegration, I run Johansen test with real money, real output and deposit rate which represent real money balances. I got one cointegrating vector at 1% level and correct signs. However, the problem is with error correction term (ECT) itself (I obtained it by clicking Proc/Make Cointegration Group, is that correct?). it has the form of zigzag. Actually this zigzag pattern, I believe, came from zigzag real output which is seasonnaly was not adjusted since the test requires instead using centered seasonal dummies. I tried to seasonally adjust only real output data and the form of the ECT has changed. Now, I don't know what to do whether use zigzag shape ECT or seasonally adjust all variables and drop centered seasonal dummies. Please, could anyone give me advice on this matter?
2) In my coinegration test, a weak exogeneity condition is violated (alpha coefficients are not zero and are significant, restrictions on alpha coefficients were rejected at 1% level). But since i am using only ECTs from long-run relationships in my anlysis of the short-run dynamics (using dynamic OLS), can I just not to take into account this violation? If I can, what is the plausible explanation then? Somewhat similar was done by Sekine (2001) "Modeling and Forecasting Inflation in Japan".
Thanks in advance, please help!
URGENTLY!!!
