check if series is all NAs (has data other than NA)
Is there a quick and built-in way to check if a series has data? From what i understand, @isna is for individual observations as opposed to the entire series.
Re: check if series is all NAs (has data other than NA)
i suppose one way is to check the min or max value. If they are NA, then i can assume it's all NAs
Not sure how much overhead there is with this method though. I suspect it will slow things down significantly if there are hundreds/thousands of series
seriesname.@obs>0
Perfect. Thanks
