Convert values to numerical values
Pantera
Postby Pantera » Wed Jan 06, 2021 1:02 pm
Hello all,
I have a variable (let's say a variable X) which has negative and positive values. Problem: I want to make a variable Y which is the numerical value of X (all values are positive). I guess it is possible to use the genr-function to do the converting, i.e. Genr Y = ???? -- but how do we do it?
Regards,
T.L.
Re: Convert values to numerical values
Postby EViews Gareth » Wed Jan 06, 2021 1:55 pm
Not sure on your terminology - negative numbers are still "numerical".
But perhaps you want the @abs function?
series Y = @abs(X)
Pantera
Postby Pantera » Wed Jan 06, 2021 3:32 pm
Thanks Gareth -- problem solved. You understood me correctly. I meant "absolute value" :-)
Regrads,
T.L.
