ECB SDMX database
ECB SDMX database
Dear Eviews,
On any request for data from ECB database, I obtain the following issue (below).
Is this problem on my side or this is common problem? Does ECB database work on your side?
EViews Katerina
Re: ECB SDMX database
Are you getting this error when you press the Browse button?
What version and build date of EViews are you using (On menu click Help->About EViews)?
I can press "Browse" and I see datasets, but then I choose any database and press "Next", and then error occurs...
I use Eviews 11 with the latest patch, Dec 8 2020 build.
EViews Katerina
Latest patches of EViews 11 (Build date Dec 14 2020 or later) contain fix for the issue.
paolo.zanghieri
I am trying downloading series using the mnemonics provided in the database (see below) but I always get an error message as Eviews cannot find them. Any clue?
thanks
dbopen(type=ecb, server=https://sdw-wsrest.ecb.europa.eu/service)
fetch YC.B.U2.EUR.4F.G_N_A.SV_C_YM.SR_10Y
thanks
paolo.zanghieri
same happens with the Bundesbank site.
thanks
dbopen(type=bbk, server=https://api.statistiken.bundesbank.de/rest)
fetch BBSIS.M.I.ZAR.ZI.EUR.S1311.B.A604.R01XX.R.A.A._Z._Z.A
thanks
EViews Alejandro
Hi Paolo,
May I know what datasets are you trying to fetch the series from?
I believe the commands you provided may have some syntax errors.
For example, this is a fetch command for getting a series in the BKN dataset from ECB database:
fetch bkn__bkn_denom=10n1.bkn_item=nc10.bkn_series=as.bkn_type=c.data_type_bkn=s.freq=m.ref_area=u2.series_denom=e
It is made by:
-fetch command
-the series dataset: "bkn"
-followed by: "__"
-the dimensions name and value (name=value), separated by "." : "bkn_denom=10n1.bkn_item=nc10.bkn_series=as.bkn_type=c.data_type_bkn=s.freq=m.ref_area=u2.series_denom=e"
Let me know if this helps you.
It is made by:
-fetch command
-followed by: "__"
paolo.zanghieri
Thanks a lot. I am trying to retrieve the Yield curve data for AAA government bonds. Yields and parameters of the NSS model
https://data.ecb.europa.eu/data/dataset ... odal=false
EViews Alejandro
For the specific series you previously shared, the command should be like this:
fetch(d=ecb) yc__currency=eur.data_type_fm=sr_10y.freq=b.instrument_fm=g_n_a.provider_fm=4f.provider_fm_id=sv_c_ym.ref_area=u2
paolo.zanghieri
Thanks, I rand the line, Eviews keeps fetching but cannot find anything
Is your copy of EViews 13 up to date?
paolo.zanghieri
I think so. I have the Aug. 8 2023 build.
thanks
thanks
You should update to the latest version.
