Hello!
I am trying to draw a horizontal line at the value 5.25 and 7 as measure on the left axis as follows: graph1.draw(line, left, rgb(0,0,127)) 5.25 and graph1.draw(line, left, rgb(0,0,127)) 7.
However, I need to draw a horizontal line at the value 5.25 for the particular period 2000-2012 (and there should be no line at 5.25 after 2012) and 7 for the period 2013-2020 (and there should be no line at 7 for the 2000-2012 period). How I can draw separate horizontal lines for different periods.
I appreciate any help. Thanks.
RE: Draw Lines
Re: RE: Draw Lines
You cannot.
Although, of course you could just create a series equal to 5.25 on the periods you want, NA everywhere else, and then add that series to your graph.
eviewsuser10
Re: RE: Draw Lines
Thank you for your response. I do not quite understand what "NA everywhere else, and then add that series to your graph" means. I attached the exemplary graph to this post. Would you please answer my questions in the file? How can I delete the line at 5 for the 2016-2020?You cannot.
How can I delete the line at 7 for the 2009-2015?
Thank you.
Dae-Young
- Draw Lines.docx
- (18.05 KiB) Downloaded 389 times
