Chart in dated panel: how to collect crossid first and date second?
mamo
Postby mamo » Mon Sep 28, 2020 2:29 am
Dear Eviewers,
I use Eviews 11 Sept 2019 built.
Is there an approach to collect crossids before dates in charts in a dated panel workpage? (See example code below)
Best, mamo
wfcreate a 2000 2010 2 series x=@trend*(3-2*@crossid) smpl 2009 2010 ' The following line creates a bar chart in which the dates are collected first, and crossids second ' (I.e., it shows x for both crossids in 2009, and then x for both crossids in the year 2010) bar(panel=combined) x 'How can one generate a bar chart in which the crossids come first, and date second? 'I.e., show x for crossid 1 in the years 2009 and 2010, and x for crossid 2 in the years 2009 and 2010?
mamo
Re: Chart in dated panel: how to collect crossid first and date second?
Postby mamo » Mon Sep 28, 2020 2:35 am
Sorry, I mixed it up, so correction of my request:
I am looking for an approach to make date appear first in the chart, and crossid second (see example code below, comments changed)
Best, mamo,
wfcreate a 2000 2010 2 series x=@trend*(3-2*@crossid) smpl 2009 2010 ' The following line creates a bar chart in which crossid comes first, date second ' I.e., it shows x for crossid 1 in 2009 and 2010, and then x for crossid 2 in both years bar(panel=combined) x 'So how to generate a bar chart in which the date comes first, and crossid second? ' (I.e., collect x for year 2009 for crossid 1 and 2 and then x for 2010 collect for 1 and 2 )?
mamo
Postby mamo » Mon Sep 28, 2020 3:05 am
Strangely, I have also observed the following behavior (well, note that this does not solve my original request):
The following code invoked from the command line provides a different chart than the same code invoked from a program
Still, strangely enough, the above line invoked from the command line indeed provides a merged chart with two separated panels, one for each crossid, (i.e. crossids are again ordered first). While the same code invoked in a program provides the same ordering - crossids come first, dateid comes second - the output looks different: it yields a single chart with a single x-axis.
(PS: is there a way to generate the same look using a program as from the command line?)
Best, mamo
