Granger causality lag length
Posted: Tue Mar 23, 2010 7:05 pm
by moojf
HI
If I performe Granger causality test on Eviews between two variables.
How can I decide the lag length neded
Re: Granger causality lag length
Posted: Wed Mar 24, 2010 8:41 pm
by random_access
i cannot remember how it looks like....is there any AIC or SC values there?
there is another way to select the right lag but first let me know about the selection criteria
Posted: Thu Mar 25, 2010 4:03 am
by moojf
In Granger causality there is no criteria
It just ask you for the lag length.
What i found that i have to choose the larger lag that match the theory
is that right?
Posted: Fri Mar 26, 2010 3:11 am
by random_access
it depends on the data frequency.
select the variables and run VAR
when the estimation output comes out go to view and then lag structure and then lag length criteria and then use 30 if u r using daily data and 12 if monthly and check the criteria.....it will give u few criteria....choose one and use it for causality
hope it help
Posted: Fri Mar 26, 2010 5:04 pm
by moojf
Thank you sir
Posted: Tue Apr 06, 2010 2:02 am
by moojf
hope it help
What about if I have a yearly observations 40 years?
Posted: Tue Apr 06, 2010 2:36 am
by random_access
i think it should be allright
Posted: Tue Apr 06, 2010 2:47 am
by moojf
sorry what you mean?
I didn`t get that?
And thanks again for your help
Posted: Tue Apr 06, 2010 3:00 am
by random_access
if u r using yearly data and u have 40 years. then u can use one year.....usually they do not go beyond.
so u can conduct Granger causality using one year back
hope it helps
Posted: Tue Apr 06, 2010 4:48 am
by moojf
That`s fair enough
Thnaks
Posted: Sun May 09, 2010 8:49 pm
by moojf
Hi Random
If I have Quartrely data 136 observation, what should i use?
Posted: Fri Dec 28, 2012 11:49 am
by DOC12
I am trying to carryout pair wise granger causality for about 16 series, I have tried using the VAR method to select the optimal lag length. It seems that the different criteria except SC (which always chooses zero) just automatically select the max lag lenth chosen, I tried up to 40 lags and I got the same thing. I know the consensus is that the optimal lag length for daily data is thirty and monthly data is twelve, but what about weekly data. Thanks
Posted: Tue Apr 09, 2013 1:31 pm
by gr031
hope it helps
I have yearly data with 13 observations. What lag length should I choose? Thanks!
Posted: Sat May 21, 2016 5:42 am
by may.k
I also would like to know the lag length for 30 annual observation. when I use lag 4, it was found uni direction. is lag length 4 appropriate for 30 annual observation?
