VBA to Eviews
Posted: Mon Jun 22, 2020 6:23 pm
by Elderfield.A
I am writing some VBA to take data from excel into eviews:
Dim shReadMe As Worksheet, shWorkingAdd As Worksheet Dim mgr As New EViews.Manager Dim app As EViews.Application Dim Path As String, SeriesName As String Dim rngAdjustedProfile As Range Set shReadMe = Worksheets("READ ME") Set shWorkingAdd = Worksheets("Working AddFactors") Set app = mgr.GetApplication(ExistingOrNew) Path = shReadMe.Range("PATH") Set rngAdjustedProfile = shWorkingAdd.Range("Q8:X8") SeriesName = shWorkingAdd.Range("VARIABLE") app.Run "wfopen """ & Path & "\output\Model.wf1""" app.Run "smpl 2020q2 2022q2" app.Put SeriesName, rngAdjustedProfile, DataTypeSeries app.Show
Everything works, except the app.put call doesnt seem to read in the range of data, but only the first observation, so in this instance the data in cell Q8 in shWorkingAdd. I have changed the cell reference and every time it is the same, reading in only the first observation in the range - NAs for everything else.
I also have tried app.PutSeries with no avail.
I am using Eviews 10+ and Excel 2016.
Any thoughts as to where I am going wrong?
Re: VBA to Eviews
Posted: Mon Jun 22, 2020 8:42 pm
by Elderfield.A
Turns out this is happening because my range runs across columns. It appears that for this to work I need the data to be transposed:
I have changed this
Dim rngAdjustedProfile As Variant, rngAdjustedProfileT as Variant
And this
rngAdjustedProfile = shWorkingAdd.Range("AdjustedProfile").Value2 rngAdjustedProfileT = Application.Transpose(rngAdjustedProfile)
Which seems to work!
However, I would be interested to know if this was indeed the issue, and if there is a better work around?
Re: VBA to Eviews
Posted: Tue Jun 23, 2020 7:09 am
by EViews Steve
EViews reads and writes a series object vertically. So transpose is the solution we recommend to people who have their data running horizontally.
Re: VBA to Eviews
Posted: Tue Jun 23, 2020 8:52 am
EViews reads and writes a series object vertically. So transpose is the solution we recommend to people who have their data running wrongly.
Fixed that for you.
Re: VBA to Eviews
Posted: Tue Jun 23, 2020 4:11 pm
by Elderfield.A
Thanks for the useful responses Steve and Gareth - personal opinions around which way data should run when people set up spreadsheets aside, it would be a nice feature to have in future. I also couldn't find any reference to this little quirk in the white paper (although I could have missed it) - are there any other quirks that are not documented that would be useful to know?
