I sometimes store a very large amount of data to a server, about 4000 series with a few years of monthly data. The way I do this currently is to store the {string} of all the series that I am going to store, but it takes quite a while for the store command to finish running (20-30 minutes).
Is there a more efficient way to do this from a processing or bandwidth perspective? It takes long enough that my corporate-controlled computer goes into sleep mode (which I think pauses the store?) if I do not hang out to babysit it, which makes the long time a little more problematic. Would opening the database first give me access to a more efficient storing command? Would doing this as a program in Quiet mode save a significant amount of time? (To be honest, I often find the status bar to be reassuring on lengthy processing times.)
My upload speed is 5 mbps, which is not spectacular, but I figure that a bunch of numbers can't really be that many megabytes.
efficiently storing large amounts of data to server
Re: efficiently storing large amounts of data to server
Could you provide a few more details - what type of file are you storing to? (EViews database - .edb, or some other kind?)
Without knowing the details yet, I can say that storing to a local database/file first, and then pushing the database/file to the network is going to be significantly faster than pushing each object over the network one by one.
For example, save everything to a local CSV text file, then copy the CSV file to your network location.
wfsave(type=txt) mydata.csv
shell copy mydata.csv x:\network\folder\mydata.csv-
Although Steve's suggestion isn't going to work if you're updating a database.
This is going to a FAME database on a server.
Speaking of servers, my server just got changed to a long and cumbersome name. Is there a way to set the server option for the fetch/store command globally so that I can leave out the "server=..." part of the fetch/store commands? Right now, I write:
fetch(d=MYBANK,t=F,server=MYSERVER) MYSERIES
and I don't really want to change to
fetch(d=MYBANK,t=F,server=MYQWERTYOMGBBQ_#&*!@#SERVER) MYSERIES
Add it to your database registry
