loading R RData file
Postby startz » Mon Apr 20, 2020 9:18 am
Tried File/open/foreign data as workfile and got told
Annotation 2020-04-20 092433.png (5.38 KiB) Viewed 16158 times
What did I do wrong? Did I have to connect to R before being able to open a file?
Re: loading R RData file
Postby EViews Steve » Mon Apr 20, 2020 10:20 am
You need to have R installed in order to open R files. Once installed, you'll have to point EViews to your R directory so that EViews can find it. To do this, open EViews and go to Options menu/General Options and then select "External program interface" in the left tree view. Then on the right, look at the Home Path text field under "R". Make sure this path is valid on your system.
By the way, the R Home Path is the R folder that contains things like the "bin" folder, the "library" folder, the README file, etc. On my system, the R path is located at: C:\Program Files\R\R-3.6.2
Postby startz » Mon Apr 20, 2020 10:38 am
Thanks. That works. Although there's a tiny bug where the cursor stays as the little running circle while over an open window.
