Mixed-Frequency VAR
paolo.zanghieri
Mixed-Frequency VAR
Postby paolo.zanghieri » Fri Apr 10, 2020 2:43 am
I am practicing on forecastign with Bayesian Mixed frequency VARS, using the kansas Fed file provided in the example. I estimated the model up to 2009Q and try to forecast, byt the Eviews crashes each time. Any clue?
thanks
Re: Mixed-Frequency VAR
Postby EViews Gareth » Fri Apr 10, 2020 8:02 am
What’s the build date of your copy of EViews? (Help->About EViews)
paolo.zanghieri
Postby paolo.zanghieri » Tue Jul 14, 2020 6:33 am
Version 11 Jun 23 2020 build (it still not working)
Postby EViews Gareth » Tue Jul 14, 2020 7:29 am
Could you provide the exact settings you are using?
AASA
Postby AASA » Sat Sep 19, 2020 12:48 pm
I have tried to forecast using Bayesian VAR with the mixed frequency VAR. The forecast program crashes each time. I notice a previous user had the same problem, but I did not see a resolution response.
Postby EViews Gareth » Sat Sep 19, 2020 1:19 pm
What is the version number and build date of your copy of EViews? (Help->About EViews)
AASA
Postby AASA » Sat Sep 19, 2020 3:07 pm
Build date: 9/8/2020
EViews version: 11
Postby EViews Gareth » Sat Sep 19, 2020 9:20 pm
Could you provide the workfile?
AASA
Postby AASA » Sat Sep 19, 2020 10:06 pm
Mixed frequency VAR file is attached. I have tried to forecast with the Bayesian method without success. The EViews YouTube does not mention that the variables need to be stationary. I assume the variables must be stationary. Looking at the Qtr. tab, VAR01 is a U-MIDAS VAR with non stationary variables. VAR02 is a Bayesian VAR with non stationary variables. VAR03 is a Bayesian VAR with stationary variables.
var mixed q3.wf1
(650.72 KiB) Downloaded 863 times
Postby EViews Gareth » Sun Sep 20, 2020 8:30 am
Thank you!
Will be fixed next patch.
AASA
Postby AASA » Sun Sep 20, 2020 11:54 am
Thank you!
You folks are wizards. As mentioned to you in the past, EViews is like a Ferrari or jet plane, and I'm just a go-cart driver or biplane pilot trying to make the most of what you folks offer. I really appreciate your videos, keep them coming.
paolo.zanghieri
Postby paolo.zanghieri » Mon Nov 23, 2020 1:24 pm
I am estimating a MFVAR with quarterly and monthly data and trying to produce nowcasts. Suppose I have quarterly data until Q2 and monthly data until August. If I understand the help file corretctly the forecast will not consider the monthy data available for Q3. Is there a way to use them?
Postby EViews Gareth » Mon Nov 23, 2020 10:06 pm
How do you want it to use it?
paolo.zanghieri
Postby paolo.zanghieri » Tue Nov 24, 2020 8:58 am
I'd like to use the monthly data to create a sort of coditional forecast for the quarterly series.
Mixed-Frequency VAR
Postby EViews Gareth » Tue Nov 24, 2020 9:06 am
You’ll have to provide more detail.
From a mathematical point of view, how do you want the model to use that August value?
