series / group data members
Posted: Thu Apr 09, 2020 8:10 pm
Is there a way to see what transformation has been applied to a series or group object? For example, when you open a series object, you have the option to change the series from "default" to "% change", via the little drop down box. I'd like to know if this information is stored somewhere in the object and can it be accessed? I am writing an add-in so a view can be chosen to format charts to my organisations requirements and one thing I'd like to do is place "Per cent" as the axis title if the user has transformed the series via the drop down box.
In addition to this, is there a way to update the "_this" command? What I want my add-in to do is essentially as follows:
The user selects a series or group from the workfile and choose "format chart" from the Procs/Add-ins menu, then the following add-in run:
If i run something like the above, I get the error "template is not a valid view for _this.template" which suggests I need to do something at step 2 before going to step 3. But I am not sure how to proceed.
Adam
' Create a line plot of the selected series / group using "_this" (1)
_this.line
'freeze this as a graph - cant seem to get this to work (2)
' change all the formats in the graph based on the desired settings (3)
_this.template userdefinedtemplate 'A template that gets created when program is run
' Update axis title with "Per cent" if user has transformed the data
if "some condition is met" then
_this.addtext(-0.3,0.25) "Per cent"
endif
Adam
