Dynamic OLS lead/lag terms and the ECM
Posted: Thu Mar 18, 2010 12:40 pm
My version is Eviews 7. I am using DOLS to estimate a cointegrating relationship, and intend to include some short run dynamics and generate forecasts by utilizing an error-correction model. My primary concern is that I proceed through this process in an appropriate sequence, but I continue to stumble over the best way to include the cointegrating relationship in the ECM.
I would like to use the Eviews DOLS functionality because of its user-friendliness. However, in discussing DOLS, the Eviews help files note that "The short-run dynamics are also used in computing the residuals used by various equation views and procs such as the residual plot or the gradient view."
My understanding is that the DOLS short-run dynamics (i.e. the lead/lag terms) are "nuisance" parameters used to generate efficient estimates, but should not be used in forecasting. If that is the case, would collecting the error terms from the Eviews DOLS estimation and using their lags as the RHS variable for the cointegrating relationship in the ECM be inappropriate?
If the answer is "yes", would it then be better to collect the coefficients on the variables that cointegrate in the DOLS step and then use them to fully specify the cointegrating relationship in the ECM equation? Or, would a better solution be to estimate the Eviews DOLS, then use the model object to generate error terms (since the help files note that "forecasting and model solution using an equation estimated by DOLS are also based on the long-run relationship"), and then finally use these error terms in the ECM? Thanks.
