if statement not working
Posted: Tue Mar 03, 2020 4:41 pm
by Elderfield.A
I am trying to use an if statement within a loop, which goes through a group and adjust a variable with another variable which is tagged "_adj_exc", the if statement is looking at the variable name and if it meets the condition, adjust the variable differently.
The code is below, the first part simply finds each variable name in the group, removes the last 8 letters (which is the string "_adj_exc") and creates the program string variable %3, this is then passed to the if statement testing the condition that the %3 = "var1" or "var2" (which it does, because I have tested it by printing %3 within the loop). However, the condition fails and the the resulting variable is constructed based on the "else" part of the code.
I am probably missing something really obvious here, but I just cant see it!
Any ideas?
group excadj *_adj_exc for !1 =1 to excadj.@count %2 = excadj.@seriesname(!1) !a = @length(%2)-8 %3 = @left(%2,!a) smpl @all {%2} = @recode({%2}=na,0,{%2}) model.scenario "1" model.exclude(m) {%3}(%period) model.override(m) {%3}(%period) model.scenario "2" model.exclude(m) {%3}(%period) model.override(m) {%3}(%period) for %1 1 2 smpl @all series {%3}_{%1} = {%3}_bl smpl %period if %3 = "var1" or %3 = "var2" then series {%3}_{%1} = {%3}_bl+{%2} else series {%3}_{%1} = {%3}_bl*(1+{%2}/100) endif next next
However, the condition seems to be ignored within the loop
Re: if statement not working
Posted: Tue Mar 03, 2020 4:44 pm
Probably a case issue. Object names are uppercase.
Posted: Tue Mar 03, 2020 4:46 pm
by Elderfield.A
right, so something like @lower(%3) should work?
