Update leading to higher run times?
Posted: Tue Mar 03, 2020 10:17 am
by twash@slu.edu
The update from eviews 10 to eviews 11, led to a drastic increase in the run time of my programs. A program that would run in five minutes can sometimes take hours. The slowdown appears to be due to it taking longer to generate equations. Does anyone else have this problem?
Re: Update leading to higher run times?
Posted: Tue Mar 03, 2020 10:27 am
by EViews Matt
Would you be able to post one of the programs that is running slowly in EViews 11?
Posted: Fri Mar 06, 2020 12:33 pm
by twash@slu.edu
I attached the program that I just ran today, it took about 30 minutes to run.
Posted: Fri Mar 06, 2020 12:38 pm
That's a workfile. Was there a .prg too?
Posted: Fri Mar 06, 2020 12:43 pm
by twash@slu.edu
Sorry wrong file
Posted: Fri Mar 06, 2020 2:20 pm
Running the program on your existing workfile (replacing all the fetches with just pageselects), and the program runs in half a second.
Thus the most likely cause in any change would be due to an increase in fetch times.
Before diagnosing further, could you confirm the build date of your copy of 11? (Help->About EViews)
Posted: Mon Mar 09, 2020 5:58 am
by twash@slu.edu
The build date is October 17th 2019
Posted: Mon Mar 09, 2020 6:28 am
by twash@slu.edu
Also saving files takes a long time as well.
Posted: Mon Mar 09, 2020 6:49 am
Can you update to the most recent version and see if the problem persists?
Posted: Tue Mar 10, 2020 6:10 am
by EViews Steve
Here's a post I wrote about Troubleshooting EViews Slowness. Please take a look at that and let us know if anything seems to work.
