Extracting exclude dates
Elderfield.A
Postby Elderfield.A » Mon Feb 17, 2020 8:35 pm
Is there any way to extract the dates that a variable is excluded. Essentially, want to be able to create a string variable that lists all the model excludes as they are in the exclude view of the model. I have used the exclude list command:
string a = model.@excludelist("scenario")
However, this simply lists the variables, it doesn't contain information regarding the sample which the variable is excluded over. Which is what I need.
Is there a way to do this?
Adam
EViews Matt
Re: Extracting exclude dates
Postby EViews Matt » Wed Feb 19, 2020 11:32 am
I'm afraid there isn't a convenient model data member for retrieving the exclusion sample. I believe the only way to access that information programmatically is to freeze and parse the Scenario View table.
Elderfield.A
Postby Elderfield.A » Thu Feb 20, 2020 9:10 pm
Hi Matt,
That is fine, could you please provide some code example as to how you would go about freezing and parsing the table? This could be useful for a number of other applications I have in mind.
Adam
EViews Matt
Postby EViews Matt » Fri Feb 21, 2020 6:31 pm
Certainly...
create u 100 ' Simple example model. series x = nrnd series y = nrnd series z = nrnd var v.ls 1 2 x y z model m m.append :v ' Example exclusions in baseline scenario. m.exclude x("1 50") y("25 75") ' Create a table from the Scenario View. freeze(tmp) m.scenlist ' Find the first row in the table corresponding to the scenario we're interested in. !row = 5 while @neqna(@lower(tmp(!row, 1)), "baseline") !row = !row + 1 wend ' Record the exclusion listed on that row. %excludes = tmp(!row, 3) ' If there are addition exclusions, they will be listed in subsequent rows. !row = !row + 1 while !row < tmp.@rows and @lower(tmp(!row, 1)) = "" %excludes = %excludes + " " + tmp(!row, 3) !row = !row + 1 wend ' Record the result in a workfile string for easy viewing. string result = %excludes
The above could be properly parameterized and turned into a subroutine, but as is it demonstrates going through the table form of the Scenario View and extracting the exclusions for a particular scenario.
Elderfield.A
Postby Elderfield.A » Mon Feb 24, 2020 10:10 pm
Thanks Matt - this is really great.
Return to “Models”
