Passing objects and variables between multiple programs
Florek
Postby Florek » Fri Feb 07, 2020 9:08 am
Dear Eviewers,
I have several very long codes which I uses for different central bank analysis. As these codes are very similar, I would like to split the codes in different smaller programs using exec and use variables as placeholder whenever possible.
More precisely, suppose the first program is a master file where I define different parameters such as
Frist Program “Master file”
'choose CB %CB = "fed" !model = 1 ‘Only string objects are passed to other programs string CB = %CB exec .\List_of_variables.prg scalar test1 = num_var_dep scalar test2 = !num_var_inf
From this I want to call a second program “list_of_variables”
if CB = "fed" then 'Create list of dependent variables string list_var_dep = "A B C" scalar num_var_dep = @wcount(list_var_dep) 'Create list of inflation %list_var_inf = "X Y Z" !num_var_inf = @wcount(%list_var_inf) endif
If I run the master file test1 = 3 but test2 is empty. Also, if the if-statement would read as
if %CB = "fed" then
both would be empty. In other words, only strings or scalar objects can be passed around between different programs but not variables such as “%list_var_inf” or “!num_var_inf”.
Why is this the case and how can I pass variables between different programs?
Later I want to loop over the list of variables, so string objects would not work. I could probably redefined string objects to variables (%list_var_dep = list_var_dep), but I think this is not very handy as I am doing this for several input / output variables. Also, I assume it must somehow be possible to pass variables to other programs.
Thanks a lot for your help in advance!
Best,
Florian
Re: Passing objects and variables between multiple programs
Postby EViews Gareth » Fri Feb 07, 2020 9:12 am
Using include rather than exec is probably the best option.
Florek
Postby Florek » Mon Feb 10, 2020 3:05 am
Thanks a lot. This works perfectly!
