Reading Text File data as dates
Posted: Wed Dec 04, 2019 12:49 pm
I am importing data through a text file that is in a time series.
cd \\Msad\root\NA\NY\lib\ER\ER18\NonResi
%filename = "\\Msad\root\NA\NY\lib\ER\ER18\NonResi\CM\comb_file.txt"
wfopen(wf=constructionmonitor) %filename @freq m
pagestruct(create) areaname @date(month)
The dates being translated from the textfile into eviews are appear as "YYYYMM" (199003) as opposed to when we upload the data from excel, the program reads the data as "YYYY"m"MM" (1990m03). As a result, in the final step of the program when we try to combine all the data with the same date, the program does not register the dates and will not create the variables "value_sample2" and "permit_sample2" (see below).
Final step:
pagecreate(id, page=Raw_Data4) month
pagestruct(freq=m,start=1993, end=2019)
link value_sample2.linkto(c=sum) Raw_Data3::value_sample @date month
link permit_sample2.linkto(c=sum) Raw_Data3::permit_sample @date month
pageselect Raw_Data4
sample compile 2003:01 2019:11
pagecopy(smpl=compile, page="compiled_data")
pageselect compiled_data
delete compile
If you can advise how to add to the program to file this I would appreciate it.
Thank you.
Final step:
delete compile
Thank you.
