Automatic ARIMA selection - Too many ARMA terms
Posted: Wed Oct 02, 2019 9:29 am
by AfonsoRod
Dear all
I am trying to use the Automatic ARIMA selection add-in to select the correct ARMA terms to use. I read that, since I have daily data, I should test for 8 maximum number of AR and MA terms (7 days +1). Also, i also want to test my data for SAR and SMA terms. Hence, I specified ARMA add-in as follows:
However, after Eviews ends the estimation I get the following message:
Too many ARMA terms
I believe that I can only use 25 ARMA terms but, since I'm testing for a max of 8 AR terms, 8 MA terms, 2 SAR terms and 2 SMA terms, making a total of 20 max ARMA terms, shouldn't it be allowed? Or am I counting my ARMA terms the wrong way?
I appreciate all the help in advance
Yours sincerely,
Afonso Rodrigues
Re: Automatic ARIMA selection - Too many ARMA terms
Posted: Wed Oct 02, 2019 10:51 am
Seasonal ARMA terms are multiplicative in the restriction.
Posted: Wed Oct 02, 2019 11:14 am
by AfonsoRod
Eviews Gareth, thank you for your answer. But even if the seasonal ARMA terms are multiplicative shouldn't it still be possible to perform the test?
8 AR terms + 8 MA terms + ( 2 * 2 SAR terms) + ( 2 * 2 SMA terms ) = 24 ARMA terms
Also, even if I only opt to put in the SAR and SMA terms the option '0' and '7', I can only perform the test if I choose a max number of AR and MA terms of 5.
Posted: Wed Oct 02, 2019 1:08 pm
It is number of AR terms * number of SAR terms plus MA*SMA
Posted: Wed Oct 02, 2019 1:54 pm
by AfonsoRod
Thank you for the help
Posted: Thu Oct 03, 2019 9:13 am
by AfonsoRod
Eviews Gareth,
I'm sorry for the pressing, but in the tests I'm doing after your last help I tried to conduct two different tests, namely:
  • - 4 AR terms, 4 MA terms, 3 SAR terms and 3 SMA terms (0, 7 and 12)
  • - 6 AR terms, 6 MA terms, 2 SAR terms and 2 SMA terms (0, 7)
If I perform the equation you mentioned in your last comment we have, in both cases, a maximum number of 24 ARMA terms, since:
  • - 3 * 4 + 3 * 4 = 24
  • - 2 * 6 + 2 * 6 = 24
However, I can perform the test in the first case, but in the second case (with the 6 AR and MA terms and 2 SAR and SMA terms) the "too many ARMA terms" error pops up again.
What am i doing wrong?
Posted: Thu Oct 03, 2019 9:21 am
Sorry, I should have been more clear.
#AR + #MA + #AR*#SAR + #MA*#SMA
Posted: Thu Oct 03, 2019 9:28 am
by AfonsoRod
Just one last thing: If in the "Searchable SAR terms" I write the options 0, 7 and 12, does that mean I have 3 SAR terms or just 2?
Posted: Thu Oct 03, 2019 9:30 am
Not sure.
As an aside, you should really use the built in automatic arima selection rather than the outdated add-in.
Posted: Thu Oct 03, 2019 9:33 am
by AfonsoRod
Not sure.
I do not have knowledge of that built in automatic arima selection. Where can I learn more about it?
Posted: Thu Oct 03, 2019 9:34 am
Posted: Thu Oct 03, 2019 9:36 am
by AfonsoRod
