String with column width
Postby tvonbrasch » Mon Jul 22, 2019 9:09 am
The SETWIDTH command can be used to set the with of a column. Is it possible to retrieve the current column width of a particular column, say using the command
!colwidth=table.@colwidth(i)
Re: String with column width
Postby tvonbrasch » Sun Jul 28, 2019 10:46 pm
Or is it a way to have a minimum column width in combination with automatic adjusted column width, i.e. the minimum kicks in if the automatic column width is below a specified minimum value?
Postby EViews Jason » Thu Aug 08, 2019 8:57 am
We will look into adding @colwidth and @rowheight members to tables in the very near future
