Error, Unable to open workfile
pschneider
Postby pschneider » Wed Jul 10, 2019 8:22 am
I'm getting an error message trying to open a workfile. "Error reading file xxx". What are possible reasons and solutions for this?
Thanks.
Re: Error, Unable to open workfile
Postby EViews Gareth » Wed Jul 10, 2019 8:28 am
Impossible to say without more details. If possible, could you upload the file?
pschneider
Postby pschneider » Wed Jul 10, 2019 9:23 am
Sure, thanks.
ms_returns_flows_orth_july9_5th_lag2_48v3.WF1
(5.66 MiB) Downloaded 2345 times
Postby EViews Gareth » Wed Jul 10, 2019 9:40 am
Looks like that file has become corrupted somehow.
Probably the easiest thing is to revert to a backup copy (or snapshot if using EViews 10 or higher).
pschneider
Postby pschneider » Wed Jul 10, 2019 10:58 am
hmm. its a newly produced workfile, from a program script (attached). is there anything to watch for on that end? for instance, would creating a group with objects from different sources cause a problem?
var_code_source_ms_struct_text.rtf
(151.23 KiB) Downloaded 1046 times
Postby EViews Gareth » Wed Jul 10, 2019 11:18 am
To be clear - you run that program, save the workfile, and then immediately try to open it, and it fails?
Also, which version of EViews?
pschneider
Postby pschneider » Wed Jul 10, 2019 11:54 am
Yeap thats correct. eviews10
Postby EViews Gareth » Wed Jul 10, 2019 12:09 pm
Could you email support@eviews.com a copy of the excel files and anything else required to run the program?
