Outlier treatment in a double loop
heer0
Postby heer0 » Mon Jul 01, 2019 1:44 pm
Hi guys,
I am using EViews 10 (Univ. ed.) and seek to implement a specific procedure for outlier treatment. In particular, I want to define outliers as observations with deviations from the median exceeding six times the interquartile range (in absolute terms). These outliers should then be replaced by the median value of the five preceding observations.
So far, my code looks like this:
'Create a blank output table to store median and interquartile range of all series in the group "xt_all" table (3, xt_all.@count+1) Xt_stat setcell(Xt_stat, 1, 1, "Statistic / Series", "l") setcell(Xt_stat, 2, 1, "Median", "l") setcell(Xt_stat, 3, 1, "Interquartile range", "l") 'Loop through all series in the group "xt_all" for !i=1 to xt_all.@count 'Enforce the correct series names %name = xt_all.@seriesname(!i) 'Obtain and store median and interquartile range for each series in "Xt_all" Xt_stat(1,1+!i)=%name Xt_stat(2, 1+!i)= @median({%name}) Xt_stat(3, 1+!i)= @quantile({%name}, 0.75) - @quantile({%name}, 0.25) next 'Loop through the number of observations of the current series for !i=1 to xt_all.@count and !j=1 to @obssmpl 'Enforce the correct series name %name = xt_all.@seriesname(!i) 'Consider each observation one by one !observation = !j 'Create a temporary vector of the five observations preceding the current observation vector temp = @fill(@elem({%name}, {!observation}-1), @elem({%name}, {!observation}-2), @elem({%name}, {!observation}-3), @elem({%name}, {!observation}-4), @elem({%name}, {!observation}-5)) 'Define rule for identifying outliers if @abs(@elem({%name}, {!observation})) - @abs(Xt_stat(2, 1+!i)) > 6*@abs(Xt_stat(3, 1+!i)) then 'Replace outliers by the median of the previous five observations @elem({%name}, {!observation}) = @median(temp) 'Delete vector "temp" before starting next iteration delete temp next
However, executing the code results in an error message since I try to loop over two different numerical variables at once.
Do you have any advice on how to proceed? Your help will be much appreciated!
Re: Outlier treatment in a double loop
Postby EViews Gareth » Mon Jul 01, 2019 2:19 pm
You want a nested loop:
for !i=1 to xt_all.@count for !j=1 to @obssmpl next next
However, looping through observations is generally a bad idea, and is not required in EViews. I think all you need to do is something like:
group prev5 x(-1 to -5) x = @recode((x-@median(x))> 6*@abs(@quantile(x,0.75)-@quantile(x,0.25)), @rmedian(prev), x)
i.e. create a group with the 5 lagged values of X. Then use the recode function to change any values of x that are greater than your condition to the median of that group.
heer0
Postby heer0 » Thu Jul 04, 2019 5:45 am
Thanks SO MUCH for your help Gareth. I tweaked your last bit of code a little:
'Loop through all series in the group "xt_out" for !i=1 to xt_out.@count 'Enforce the correct series names %name = xt_out.@seriesname(!i) 'Define a temporary group for each series with its five lags group prev5_{%name} {%name}(-1 to -5) 'Replace outliers {%name} = @recode(@abs({%name}-@median({%name}))> 6*@abs(@quantile({%name},0.75)-@quantile({%name},0.25)), @rmedian(prev5_{%name}), {%name}) 'Delete the current temp group from work page delete prev5_{%name} next
Now it works as intended. Thank you again for pointing me into the right direction! You are the best. ;)
