Error message when graphobjects are displayed
Posted: Thu Jun 27, 2019 10:09 pm
by johansamuelsson
When creating graph object I usually get data from other workfiles directly instead of first copy them in the same workfiles where the graphs are produced.
The workfiles whit the data is sometimes updated, removed or not available. My idea is that this should not affect the workfile with the grapobject.
So if I later open the workfile with the graps and shows the graphobjects Eviews reports a error message (but only for those graphs where there is a function included in the expression of the line/bar)
In the codeexampel below I get "C:\TEMP\DATA1.WF1::A\SERIES1 is not a valid index for @PCY in "SHOW G3" on line 17.", but after the error message everything seems ok.
Is this a bug?
(Eviews Enterprise Edition 11 – Jun 25 2019 build)
Regards Johan
LogMode(name="logg",filename="c:\temp\error.txt", autosave=on, clearfile) error Cd c:\Temp WfCreate(page=a) a 2010 2020 Series series1 = @Trend WfSave c:\temp\data1.wf1 Close @All WfCreate a 2010 2020 Graph g1.Line data1.wf1::a\series1 Graph g2.Line data1.wf1::a\series1*100 Graph g3.Line @Pcy(data1.wf1::a\series1) Shell del c:\temp\data1.wf1 WfSave c:\temp\data2.wf1 Show g1 Show g2 Show g3
Re: Error message when graphobjects are displayed
Posted: Mon Jul 01, 2019 4:10 pm
by EViews Jason
We are looking into the issue and will get back to you shortly
Posted: Tue Jul 02, 2019 10:40 am
by EViews Jason
Internally, the @-functions require special processing. While the behavior is not ideal, it is correct.
We are looking into suppressing the error, but it will more than likely remain.
Posted: Sun Jul 14, 2019 4:49 am
by johansamuelsson
Great if it could be avoided
:D
Posted: Tue Sep 10, 2019 6:23 am
by johansamuelsson
Or if there was a global command or settings that completely hide (turning off) all error message
Regards Johan
