Theil Statistics Programme Command
Saakshi
Postby Saakshi » Mon Jun 24, 2019 3:42 pm
Hello everyone,
Can someone really help me out? I badly need help!
I am doing out-of-sample forecast. Following is my program:
gg_outsmpl.prg
Out-of Sample Forecast for H horizon
(3.16 KiB) Downloaded 567 times
As a forecast evaluation test, I also want to check the Theil statistics. I have tried with @theil command but is unable to find the appropriate result.
Please help me out with the problem.
Best,
Saakshi
Re: Theil Statistics Programme Command
Postby EViews Gareth » Mon Jun 24, 2019 3:57 pm
All of the forecast evaluation type statistics (@rmse, @mse, @mape, @smape, @theil) work as:
!mystat = @theil(y_actual, y_forecast)
where y_* are series objects.
Saakshi
Postby Saakshi » Mon Jun 24, 2019 4:17 pm
Hello Gareth, thank you for help.
I did post the command but was unable to generate the result. Following is the command file. Kindly let me know where am I making mistake.
gg_outsmpl_trial.prg
(3.23 KiB) Downloaded 678 times
Gareth, I am very new to the command program, so kindly help me out this.
Thanks,
Saakshi
Postby EViews Gareth » Mon Jun 24, 2019 4:36 pm
You don't appear to be storing the theil statistic anywhere.
Saakshi
Postby Saakshi » Mon Jun 24, 2019 4:53 pm
HORIZON h=1 h=2 h=3 h=4
Bias 0.522 1.026 1.434 1.591
MSE 3.136 5.300 8.923 12.197
RMSE 1.771 2.302 2.987 3.492
SE 1.692 2.061 2.620 3.109
MAE 1.486 2.000 2.466 2.525
MAPE 0.664 1.051 0.910 0.648
THEIL 0.000 0.000 0.000 0.000
This is my result window.
Saakshi
Postby Saakshi » Mon Jun 24, 2019 5:03 pm
Where should I store the statistics ideally?
Am I missing something here?
Saakshi
Postby Saakshi » Mon Jun 24, 2019 5:09 pm
Hello, I understand this must be a very simple question but I am in the learning phase and I badly need your help.
kindly help!
Saakshi
Postby Saakshi » Tue Jun 25, 2019 2:05 am
Hi Gareth,
I am trying to write following command for Theil. Could kindly you tell me what mistake is in this?
THEIL=@sqrt(RMSE)/@sqrt({%v}-{%v}(-1))*@sqrt({%v_f}-{%v_f}(-1))
Thanks,
Saakshi
Postby EViews Gareth » Tue Jun 25, 2019 7:27 am
I see nothing wrong.
