Eviews 11 crashes while copying or saving data
Posted: Tue May 21, 2019 12:03 am
by ErikG
Eviews 11 works well most of the time. However it occassionally crashes without reporting an error. I don't know what the exact reason is, but it appears to be related to instances when I copy or save lots of data.
I have two different prg files where it crashes. In these, it always crashes. In others it never does. The prg files work fine with Eviews 10, although they are a bit slow.
In one of these problematic files the crash occurs somewhere here:
Copy C:\temp\Dri80.wf1::a\n* Copy(m) C:\temp\FVTI2.wf1::a\n* Copy(m) C:\temp\FV2.wf1::a\n* Copy(m) C:\temp\TI.wf1::a\n* Copy(m) C:\temp\DRI2.wf1::a\n*
Each workfile I am copying from contains between 1000 - 5000 series or so that I am trying to copy. Many of them overlap.
I will use Eviews 10 when I have problems so it's not an urgent problem. Unfortunately I cannot send you the actual data.
Thanks,
Erik
NIER, Stockholm.
Re: Eviews 11 crashes while copying or saving data
Posted: Tue May 21, 2019 8:11 am
by EViews Steve
What's your build date for EViews 11? Also, can you narrow down which copy line is causing the crash? If so, save a copy of your workfile before that line, then see if performing that one line still causes the crash.
Posted: Mon May 27, 2019 12:31 am
by ErikG
I installed the may 9 patch today, and it is still crashing.
Stopping the prg file and running the next copy command via the command window also causes a crash.
Thanks,
Erik
Posted: Mon May 27, 2019 6:08 am
Could you install the latest patch and try again?
Posted: Fri Aug 09, 2019 12:04 am
by ErikG
It works fine now thanks, sorry for the late reply.
/Erik
Posted: Mon Jun 01, 2020 6:23 am
by paolo.zanghieri
Hi, I have a similar problem. Eviews crashes when I try to export data in Excel. I am using version 11, updated to May 27. thanks
Posted: Mon Jun 01, 2020 4:45 pm
by EViews Steve
Please send me a copy of the workfile you are using and details on how you are doing the export (copy? wfsave?). You can send me the workfile via email to steve@eviews.com.
