Near singular matrix error
Vermeiren
Postby Vermeiren » Mon Apr 29, 2019 2:56 am
I'm estimating following model using a system with 2sls.
gdp_deflator = c(1)*ulc + c(2)*gdp_deflator (+1) + c(3)*gdp_deflator (-1)
c(1)= (1-c(4))*(1-c(5))*(1-c(6)*c(5))/(c(5)+c(4)*(1-c(5)*(1-c(6))))
c(2) = c(6)*c(5)/(c(5)+c(4)*(1-c(5)*(1-c(6))))
c(3) = c(4)/(c(5)+c(4)*(1-c(5)*(1-c(6))))
@inst gdp_deflator (-1) gdp_deflator (-2) gdp_deflator (-3) gdp_deflator (-4) long_short_interest_rate_spread long_short_interest_rate_spread (-1) long_short_interest_rate_spread (-2) long_short_interest_rate_spread (-3) hptrendbbp hptrendbbp (-1) hptrendbbp (-2) hptrendbbp (-3) labor_income_share labor_income_share (-1) labor_income_share (-2) labor_income_share (-3)
data eviews.xlsx
(30.11 KiB) Downloaded 871 times
When i do this i get the 'Near singular matrix' error but i don't know how to solve this.
Can someone help me with this?
Thank you in advance
data eviews.xlsx
(30.11 KiB) Downloaded 840 times
EViews Matt
Re: Near singular matrix error
Postby EViews Matt » Tue Apr 30, 2019 9:01 am
Curious, that's not the issue I experience when I attempt to perform the estimation you describe. Could you provide your EViews workfile with the system object ready to estimate?
Vermeiren
Postby Vermeiren » Thu May 02, 2019 12:33 am
Hello
i'm currently using the student lite version of Eviews so i am not able to export my work.
I have attached a photo of my workfile and the system i use. I hope this will be helpful for you.
EViews Matt
Postby EViews Matt » Thu May 02, 2019 11:02 am
I suspect this is a starting values issue (your coefficient object c is probably all zeros, which is creating problems when the coefficients are first used in your system). Randomize the starting coefficients by running the command "rnd(c)" in the command window before attempting the estimation again.
Selim
Postby Selim » Mon May 06, 2019 8:53 pm
I received the same message.
But after deleting one of the variables, This message does not exist.
Because eviews does not accept exact collinearity among variables .
regards.
