Datastream "logged out" everyday
Posted: Thu Apr 11, 2019 1:18 am
by blb22
I have Eviews 10 and currently connect to the Datastream Online Database.
But every day when i open up Eviews it asks me to input my Datastream credentials again. Is there a way to save them somehow, because it prevents programmes from running automatically.
Ben
Re: Datastream "logged out" everyday
Posted: Thu Apr 11, 2019 8:31 am
by EViews Jason
Does your program start with opening the Datastream database via the 'dbopen' command?
If it does not, try adding it before any fetch calls and do the below as well.
If it does, as part of the options list you can add your credentials. http://www.eviews.com/help/helpintro.ht ... bopen.html
For example,
dbopen(t=datastream, username=myusername, password=mypassword)
If you wish not to include the credentials in the program, add Datastream to your database registry (Options->Database registry...) and at the beginning of your program add the dbopen call but unlike the above call use the database alias instead of the full specification.
dbopen datastreamalias
Posted: Mon Mar 09, 2020 4:08 am
by DBW
Hi there,
I'm having the same problem as the user above, and have tried the solutions suggested but without any success.
I've set up my PC to run a series of programs overnight, and this issue is causing it to fail. Do you have any more thoughts on why this could be happening?
Thanks.
Posted: Mon Mar 09, 2020 8:44 am
by EViews Jason
If you added Datastream to your Database registry, at the beginning of your program adding the line
should resolve the issue.
If you are still experiencing issues send me an email to jason@eviews.com and we can figure out what is going on.
