LogMsg bug?
Posted: Mon Apr 01, 2019 9:36 am
by johansamuelsson
I have two files
c:\temp\p1.prg
LogMode(name="logg") LogMsg LogMsg 11 Exec c:\temp\p2.prg LogMsg 12
and c:\temp\p2.prg
LogMsg TEST
When running p1.prg Eviews ouput (in the log) is
11
12
I expected
11
TEST
12
Or am I wrong?
Regards Johan
Re: LogMsg bug?
Posted: Mon Apr 01, 2019 11:34 am
by EViews Katerina
If your p1 was :
LogMsg 11
include c:\temp\p2.prg
LogMsg 12
Then the output in the log window would be:
11
TEST
12
The exec command executes another program. The include statement includes the contents of another file in a program file.
Using the exec command you need to add logmode to your second program ;
logmode l
LogMsg TEST
then a second log would open and display
TEST
Re: LogMsg bug?
Posted: Tue Apr 02, 2019 11:20 am
by johansamuelsson
Ok, thanks
Regards Johan
Re: LogMsg bug?
Posted: Wed Apr 03, 2019 5:47 am
by linkan
The prg-files Johan showed worked up until the most recent patch, in witch this behaviour was removed. Is there a reason that it is removed?
Re: LogMsg bug?
Posted: Thu Apr 04, 2019 1:02 pm
by EViews Katerina
We have an internal discussion about the issue. We will update you once is resolved.
Re: LogMsg bug?
Posted: Tue Apr 16, 2019 2:31 pm
by EViews Katerina
With the latest patch we reverted to previous behavior of EViews10 for logging program messages when exec command is used inside a program:
p1.prg :
LogMode l
LogMsg 11
exec p2.prg
LogMsg 12
p2.prg:
LogMsg TEST
11
TEST
12
EViews11 behavior is changed and the program that is being executed with exec command will require a LogMode command and log messages will be displayed in a new dialog as described in previous post.
Re: LogMsg bug?
Posted: Wed Apr 17, 2019 12:32 am
by linkan
Why is this change implemented in Eviews 11? It feels strictly worse than the Eviews 10 behaviour. At least it should be possible to get the old behaviour with a Logmode option.
Re: LogMsg bug?
Posted: Tue Aug 04, 2020 12:14 pm
by tvonbrasch
Have you done anything with this logmsg-issue?
t
