error when seasonally adjusting multiple series
Posted: Fri Mar 08, 2019 8:47 am
by pcruzd
I am having trouble when seasonally adjusting (x13) multiple series. I am getting an error that appear only certain times and I have to run the exactly same code 5 to 6 times until the error magically doesn't appear. The error that I am getting is: 'Unable to open file c:\users\username\appdata\ev_temp\evx13tmp.spc in "SER{!X}.X13("SAVE="D11 D10")". Please help
PS. I'm using Eviews 9.5
Re: error when seasonally adjusting multiple series
Posted: Fri Mar 08, 2019 9:02 am
That error indicates that something went wrong inside the X-13 executable. Unfortunately we don't have any control over what goes on inside it, so there isn't much we can say.
Posted: Thu Mar 21, 2019 7:03 am
by pcruzd
Thanks Gareth,
So far I've been able to manage it using setmaxerror and @errorcount, but Im having a problem when additional errors appear (like no seasonallity in the series). So I would like to know if there's any way to know what type of error im getting while running the program. For instance, to generate a lable with the text that appears in the log file when an error occurs.
Actually, my code is
!err = 0 for !x = 1 to 50 SER{!X}.X13("SAVE="D11 D10") !newerr = !err + @errorcount if !newerr>!err then !err = !newerr !count = 0 !maxcount = 20 while !count <= !maxcount SER{!X}.X13("SAVE="D11 D10") !newerr = !err + @errorcount if !newerr=!err then exitloop endif !count = !count+1 wend endif next
Posted: Thu Mar 21, 2019 7:29 am
by pcruzd
I just realized I posted an old code with errors, here is the actual one:
for !x = 1 to 50 !err = @errorcount SER{!X}.X13("SAVE="D11 D10") !check= @errorcount-!err if !check>0 then !count = 0 !maxcount = 20 while !count <= !maxcount !err = @errorcount SER{!X}.X13("SAVE="D11 D10") !check= @errorcount-!err if !check=0 then exitloop endif !count = !count+1 wend endif next
