Import of Excel files generated by R
Posted: Fri Feb 22, 2019 10:38 am
by kganev
Dear all,
I am trying to import in EViews (versions 9.5 and 10+) Excel files that are generated using R packages such as openxlsx and writexl. The files are seamlessly opened in MS Excel 2013 and 2016 but cannot be imported using the import command. I am attaching an example xlsx file here.
What I was able to see was that the xml files that underlie the xlsx's are different from the ones generated by MS Excel itself.
I would be grateful for a solution (different from re-saving the files in Excel or using csv).
Re: Import of Excel files generated by R
Posted: Fri Feb 22, 2019 3:32 pm
by EViews Jason
The xlsx file is missing the 'spans=' attribute for each row. Without the 'spans' attribute, EViews cannot tell (without great difficulty) how many columns are in a row.
You can either re-save the Excel file (which you've already mentioned you don't want to do) or ask the authors of writexl to add the 'spans' attribute to the row specification.
Posted: Sat Feb 23, 2019 1:04 am
by kganev
Thank you for your reply. I will write to the package authors.
