Import SQL data to the same page created
Posted: Fri Feb 15, 2019 9:01 am
by lgazire
Hi there!
I have an eviews program that currently is being migrated to SQL, i´m new to eviews, is there a way to show the result in the same page as the created the workfile?
This is how i created:
wfcreate(wf=passthrough, page=home) d5 1/1/2007 12/31/2019
i want to store the result of the below query in the home page:
pageload(type=odbc, page=home) "Description=desc;DRIVER=ODBC Driver 13 for SQL Server;SERVER=localhost;Trusted_Connection=Yes;APP=EViews;DATABASE=iec;" "querycode"
What is the right approach to do it?
Re: Import SQL data to the same page created
Posted: Fri Feb 15, 2019 9:28 am
Try using import rather than pageload.
Posted: Fri Feb 15, 2019 9:30 am
by lgazire
If i change to import it shows the error:
Incomplete date specification (no start date provided) in "IMPORT(TYPE=ODBC, PAGE=HOME) "DESCRIPTION=DESC;DRIVER=ODBC DRIVER 13 FOR SQLSERVER;SERVER=LOCALHOST;TRUSTED_CONNECTION=YES;APP=EVIEWS;DATABASE=DATABASE;" "SELECT ID, PRODUCTNAME FROM PRODUCT WHERE ID = 15"".
Posted: Fri Feb 15, 2019 9:38 am
by lgazire
Sorry, i just read the help for import and check that i need to pass the @append. But if i do this overwrites the resid that i had with the wfcreate
Posted: Fri Feb 15, 2019 10:00 am
resid is meaningless, overwriting it should be fine?
Posted: Fri Feb 15, 2019 10:08 am
by lgazire
Hmm, didn´t know that, i thought that it was used. Thanks!
