lag in MIDAS
Posted: Mon Dec 24, 2018 9:52 pm
by Jcool
I am currently using MIDAS in Eviews. Looking at the example (see attached) on Eviews web, the estimated result shows the estimated coefficients of the high-frequency independent variables and it starts from lag1 onwards.
Working on my data (see the file under the name of "query"), I couldn't get Eviews to show the estimated coefficients of the high-frequency independent variables from lag1. May I know if there is a way that I can adjust the setting to show estimated coefficients of the high-frequency independent variables from lag1 onwards?
Thank you.
Re: lag in MIDAS
Posted: Tue Dec 25, 2018 1:17 am
No, we changed the labeling at some point to more accurately reflect. In the bottom picture you should minus 1 from the lag definitions.
Re: lag in MIDAS
Posted: Thu Dec 27, 2018 12:08 am
by Jcool
Thanks for the information.
May I please check with you if the estimated coefficient of lag0 captures the contemporaneous effect between the high-frequency (independent variable) and low-frequency (dependent variable)?
Thank you.
Re: lag in MIDAS
Posted: Thu Dec 27, 2018 10:14 am
Depends on what you mean by contemporaneous (that term is complicated in a mixed frequency setting).
Here's a program that manually estimates an Almon lag model and computes the lags. You can see what's going on.
!xlags = 4 !ylags=0 !horizon=-2 !polyorder = 3 close @wf wfopen(wf=midas, page=quarterly) .\mydata.xlsx range="Sheet1" pageload(page=monthly) .\mydata.xlsx range="Sheet2" series x = dlog(value)*100 series x1 = dlog(value(-!horizon))*100 'create monthly lags for !i=2 to !xlags series x!i = x1(-!i+1) next for !i=1 to !xlags series z!i=x!i(-2) next 'copy monthly data over as individual time series, one for each lag. pageselect quarterly series y = dlog(value)*100 smpl 1985 2009/1/1 for !i=1 to !xlags copy(c=l) monthly\z!i x!i next 'create polynomial for !i=1 to !polyorder series z!i=0 next for !i=1 to !xlags for !j=1 to !polyorder z!j = z!j + !i^(!j-1)*x!i next next group xlags z* group ylags for !i=1 to !ylags ylags.add y(-!i) next equation eq2.ls y c xlags ylags show eq2 'calculate monthly lags matrix(!xlags, !polyorder) a for !i=1 to !xlags for !j=1 to !polyorder A(!i,!j) = !i^(!j-1) next next 'monthly lags = A*midas coefficients from equation. vector mlags = A*@subextract(eq2.@coefs, 2,1,1+!polyorder,1) show mlags equation eq1.midas y c @ monthly\x show eq1
