Merging coefficient in series (Updated) - Not correct mean
Posted: Sun Nov 18, 2018 2:39 am
by phoenix1914
Hello all
I am new to programming with Eviews 10 so I am struggling a bit with the following case. I managed to create a script to run a monte carlo simulation, in order to "prove" the assumptions of OLS estimators. More specifically I use a population function with two given coefficients (slope and intercept) and 10 given values of the independent variable (X). Also with the following script I create 20 different disturbance term (u) values, with mean zero and variance 4.
Based on the above I obtain 20 different fitted values (y) which then I regress on X, from where I get 20 OLS lines and 20 pairs of coefficients.
What I want is , if there is a quick way to merge all different pairs of coefficients in a series so I can then calculate their means and variances etc? Also can I have a series where it stores the variances of its of the OLS equations? Currently I only have 20 different equations and 20 different coefficient variables with two values each.
EDIT:
I managed to find formulas to store the coefficients and the variance of the residual (which I post below).
Now I have another issue. Based on the experiment, the variance of the residuals based on the different iterations should approximately be close to the "real" value, but when I check the stored values of the object "sevec" which stores the variances of the residuals of each run, the mean value is always 1 less than the actual. E.g. in the code below I want a disturbance term with mean 0 and variance 4, but I get approximately variance 3 even if i run more than 100 iterations.
Is there an error in the formula: series u{!i} = 0 + @sqrt(4)*nrnd ?
scalar iterations = 51 matrix(2,iterations) mycoefs vector(iterations) sevec for !i=1 to iterations series u{!i} = 0 + @sqrt(4)*nrnd series y{!i} = b1_c + b2_c* x + u{!i} equation eq{!i}.ls y{!i} c x coef c{!i} = c colplace(mycoefs, eq{!i}.@coefs, !i) sevec(!i) = (@stdev(resid))^2 next matrix mycoefs = @transpose(mycoefs)
Thank you in advance!
Re: Merging coefficient in series (Updated) - Not correct mean
Posted: Mon Nov 19, 2018 2:16 pm
by EViews Matt
I believe you're just observing the consequences of a small sample size. Try increasing the number of points from 10 to, say, 100.
Posted: Mon Nov 19, 2018 3:47 pm
Hi Matt,
I don't think this is right. Given normal errors and fixed X, E(s^2) is exact in small samples.
There is another possibility: It may be that more Monte Carlos are needed for the mean of s^2 to be estimated well.
Posted: Mon Nov 19, 2018 3:55 pm
Actually, one more possibility: You're looking at something wrong. Is your copy of EViews up-to-date?
I ran the code you posted and got a mean of 3.9938.
Posted: Tue Nov 20, 2018 9:49 am
by EViews Matt
Something about this is bothering me. Shouldn't the expected variance of the residuals asymptotically approach (from below) the true variance of the generating process (as written in the original author's script) as the sample size increases? The extreme boundary example is n = 2, where the residual variance is zero, regardless of the generating process. With a sample size of 10, I observe an average that fluctuates around 3.6. This remains consistent if the number of iterations are increased. However, increasing the number of observations pushes the average towards 4.0.
Posted: Tue Nov 20, 2018 10:11 am
I don't think so. Under the classic assumptions, s^2 is an unbiased estimator. So there is Monte Carlo error on finding it's mean, but the actual mean doesn't depend on sample size.
Posted: Tue Nov 20, 2018 1:36 pm
Use @stdevs rather than @stdev
Posted: Tue Nov 20, 2018 2:30 pm
by EViews Matt
Created a small EViews program (further below) to explore the expected residual variance for different sample sizes. I believe this shows the same numerical phenomenon that underlays the original poster's question.
The generating program:
create u 19 !iterations = 10000 series n = @trend + 2 series exp_var for !i = 1 to @obsrange !n = n(!i) !v = 0 pagecreate u !n series x = @trend for !j = 1 to !iterations series y = x + 2 * nrnd equation eq.ls y x c !v = !v + @vars(resid) next pagedelete Untitled1 exp_var(!i) = !v next exp_var = exp_var / !iterations group g n exp_var show g
Posted: Tue Nov 20, 2018 2:56 pm
I will admit to being puzzled.
A small piece of where I'm puzzled is what we're seeing for exp_var. Isn't that a series 10,000 long?
Posted: Tue Nov 20, 2018 3:14 pm
by EViews Matt
No, the series are very short (following the OP's example), only of length n. The 10,000 is the number of iterations for building the expectation (i.e. Monte Carlo runs). So, for example, drawing 3 Y's from N(0, 4), regressing, and calculating the variance of the residuals 10,000 times results in an expected residual variance of about 1.997...
Posted: Tue Nov 20, 2018 3:23 pm
Sorry. I see what you did now.
Posted: Tue Nov 20, 2018 3:30 pm
The answer is that you can't use @vars or @std. Those divide by n-1. The regression has a constant and X. The SSR needs to be divided by n-2. Do that and I think everything will work.
Posted: Tue Nov 20, 2018 3:57 pm
by EViews Matt
Of course, we've lost two degrees of freedom, that's the correction! Adjusting the original author's variance calculation now produces the expected result,
sevec(!i) = @sumsq(resid - @mean(resid)) / (@obsrange - 2)
Posted: Thu Dec 13, 2018 2:11 am
by phoenix1914
Thank you all, I'm really grateful for all these replies! i didn't respond earlier due to busy schedule and catching up with other units on econometrics, but I believe this is the answer I was looking for.
I will test it and let you know if that works out!
