How is/How to generate constant (other than 0's)?
Posted: Thu Nov 15, 2018 12:24 am
Hi all, I assume it may be a trivial question but nevertheless important for me. I have recently started working with Eviews (as normally I work in excel and stata) and I can see that when I create date series (open Eviews and select monthly intervals adding the dates between 2002M06-2007M07), the constant is being generated as 0's. In the other data set that I have recently received from my colleague, I can see constant having numerical values. His dataset has 77 time-series variables, whereas mine has 2400. How are the values for the constant generated and on what basis in Eviews?
E.g. I would add a number of time-series variables to my work file. Would that change the constant in "c"? I need the constant variable to replicate the result in Stata.
Rob
Rob
