EqTabs - add AIC and SIC values to table
Posted: Sat Oct 13, 2018 8:35 pm
by mreitrics
Hello EViews Users,
Is there any ways to add other estimator values like AIC, SIC and DW to the bottom of the EqTabs (EqSumTab)?
In the eqsumtab.prg can I just grab sets of codes and modify them?
For example, I'm assuming these sets of codes are what list F-prob to the bottom of table. These codes are from different lines/locations of eqsubtab.prg, and they are separated by "------------------------"
!doFProb = 0 'Add F-prob ------------------------ %FPDP = "4" 'Number of decimal plaecs to display the F P-val ------------------------ %temp = @equaloption("FProb") if @len(%temp) then !doFProb=1 %FPDP =%temp else !doFProb=0 endif ------------------------ if !doFProb = 1 then !fpval = 1-@cfdist(@abs({%eqname}.@f),{%eqname}.@ncoef-1,!df) 'calculate f pvalue %fpval = @str(!fpval,%fpformat) 'convert to string {%tabname}(!rowcounter+1+!doObs+!dor2+!dofstat,!colcounter) = %fpval endif ------------------------ if !doFProb then 'add F p-value {%tabname}(!rowcounter,1) = "Prob(F-stat):" {%tabname}.setfont(!rowcounter,1) +i !rowcounter = !rowcounter+1 endif
Could I just somehow modify them to pull AIC. If so, what is the variables that pull the AIC?
Thank you
Re: EqTabs - add AIC and SIC values to table
Posted: Sat Oct 13, 2018 10:06 pm
Yep. I am on my phone in the middle of Korean the jungle at the moment, so can’t see original program, but there will be something along the lines of {%eqname}.@fstat which you can replace with {%eqname}.@aic
