Hi all,
I have a datafile with seven cross-sections (countries) and 131 time observations. I have several explicative variables available for each of the seven countries, but for some of other explicative variables, they are available for four, five or six countries only.
I tried to structure my workfile as undated or balanced panel. But when running the estimate (OLS), eviews excludes the three countries for which all explicative variable are not available and run the estimates as if the panel data was balanced (only four cross-sections are used in the estimation process). When I exclude these variables that are not available for the seven countries, all the seven cross-sections are taken into account.
So my question is: Why I can't run panel estimates over unbalanced data where some explicative variables are not available (i.e. any point/value) for some inputs of the cross-section?
I attach my workfile (equation object "linear"). The variables that are not available for the seven cross section are china_fdix china_pfm china_fdim.
thank you
Unbalanced panel data
- untitled.wf1
- (262.61 KiB) Downloaded 546 times
Re: Unbalanced panel data
Observations are only included in a regression when all the variables have values for a that observation.
So an unbalanced panel is a one where there are missing values while the explicative variable remains available for all cross-sections?
Thank you
Thank you
Almost. You don't have to have all values for all cross-sections, but you do need all values for some cross-sections.
