File IO Failed
dhityayl
File IO Failed
Postby dhityayl » Fri Oct 05, 2018 3:55 am
I have a code for loop programming below. So basically i loop a rolling regression and after that i want to save to excel.
The code below works for the looping itself (without wfsave), but in the middle of the looping with wfsave, the loop failed. The error message is : File IO failed for file 'Could not create entry in zip file.' in "WFSAVE(TYPE=EXCELXML) "C:\USERS\DHITYA\DESKTOP\2\2001.T.CSV.XLSX" @KEEP DATE RETURN G1".
Is there something wrong with the code? It works before with just 2 files, but when i do 50 files, it failed.
If i want to try running the program again with different data, i should create a new destination folder to save my file, but it will failed again in the middle of the loop.
Thankyou
cd "D:\Thesis_Loop\2002_2\dataset" %filenames = @wdir("D:\Thesis_Loop\2002_2\dataset") for !k=1 to @wcount(%filenames) %file = @word(%filenames, !k) wfopen %file import D:\Thesis_Loop\2002_2\dataset\index\Indeks_2002.csv import D:\Thesis_Loop\2002_2\dataset\index\FF3_2002.csv genr return=(((close-close(-1))/close(-1))*100)-rf !window = 60 !step = 1 !length = @obsrange equation eq1 !nrolls = @round((!length-!window+1)/!step) matrix(5,!nrolls) coefmat!k !j=0 for !i = 1 to !length-!window+1-!step step !step !j=!j+1 smpl @first+!i-1 @first+!i+!window-2 equation eq1.ls return c indeks mkt_rf smb hml colplace(coefmat!k, eq1.@coefs,!j) matrix(!nrolls,5) r1 matrix r1=@transpose (coefmat!k) series rbc series rbindeks series rbmkt series rbsmb series rbhml group g1 rbc rbindeks rbmkt rbsmb rbhml sample s1 @first+59 @last mtos(r1, g1, s1) if @isobject("s1") then delete s1 endif %path = "C:\Users\Dhitya\Desktop\2\" + %file + ".xlsx" wfsave(type=excelxml) %path @keep date return g1 'close @all next next
Re: File IO Failed
Postby EViews Jason » Fri Oct 05, 2018 8:57 am
Is it failing on the same file every time (i.e. does the error message always refer to C:\USERS\DHITYA\DESKTOP\2\2001.T.CSV.XLSX)?
Can you post the list of filenames in the C:\USERS\DHITYA\DESKTOP\2 directory?
dhityayl
Re: File IO Failed
Postby dhityayl » Fri Oct 05, 2018 3:27 pm
Hi. It works fine on other computer. I think the problem is not on the eviews program.
Thank you
Re: File IO Failed
Postby EViews Jason » Wed Oct 10, 2018 7:21 am
I would then verify all the paths and files that are being referred to in your program exist. For example, make sure C:\USERS\DHITYA\DESKTOP\2\ and D:\Thesis_Loop\2002_2\dataset\index\ exist.
ashyam
Re: File IO Failed
Postby ashyam » Tue Jan 19, 2021 10:31 am
I have the same issue as stated above.
The paths and files referred to in my program do exist and are correct.
I've written the code here, its a basic code to export the cl1 series to a new excel file titled TEST1 -
include k:\hugob\eviews\program\startup.prg
pageselect monthly
smpl @all
%smpl_test="2000M1 2020M12"
smpl {​​​​​​​%smpl_test}​​​​​​​
fetch(d=hugo) cl1
wfsave(type=excelxml) K:\Ashwin.Shyam\TEST\TEST1.xlsx @keep cl1 @smpl {​​​​​​​%smpl_test}​​​​​​​
Re: File IO Failed
Postby EViews Gareth » Tue Jan 19, 2021 10:39 am
Change the folder location to something on C and see if that fixes it.
JC198998
Re: File IO Failed
Postby JC198998 » Fri Apr 11, 2025 1:00 am
I'm having the same issue. Is there a way to verify or fix the issue?
