Hi there,
I have two problems. First, I am unable to import hourly data into Eview (I am using version 6) from excel. Even if I tried to cut-and-paste the date (after changing the properties to date-time) I am unable to restructure the data such that it make sense for time series analysis.
I tried to follow the advice given in another forum link (http://forums.eviews.com/viewtopic.php? ... urly#p6192) but i have no idea what it is trying to tell me to do and I can't use the command! I don't even understand how the command code (@dateadd(day, hour-1, "h")) works.
Secondly, can anyone advise how to do TAR (Threshold Autoregressive) time series modelling in Eviews?
Really appreciate any help on this matter as I urgently need to do a project for my class! :(
Hourly Data and TAR modelling
- Processed GBPUSD v1.xls
- This is the data set that I am using. Pls help as I need to import the hourly data and do time series analysis. Thanks.
- (1.04 MiB) Downloaded 415 times
Re: Hourly Data and TAR modelling
EViews 6 doesn't support hourly data. You'll have to upgrade to 7.
Ok, now i have eviews 7 can you advise how do i do hourly data manipulation and then do a TAR modelling, pls?
Once you've opened that file up in EViews you should be able to structure it (click on Proc->structure/resize current page) as "dated - specified by date series", and enter "date_time" as your date series. EViews should then recognise the date format of your data.
TAR estimation isn't built into EViews, so I can't help you with that.
