Forecasting mean equation of a Multivariate VAR-GARCH: Using code
Posted: Wed Aug 15, 2018 7:21 am
by pvestia
I create a simple code to perform a multi-step forecast of VAR(1)-BEKK-GARCH(1,1)
But every time I run the code, the estimated series change every time. Can you guys give a look at the code and tell me with something is wrong or If what I'm doing is right?
Thank you in advance.
Best regards.
' define the range for the 12 month forecast range @first @last+12 'THE LOOP STARTS ' define loop for a 12 month forecast for !i=1 to 12 ' make the VAR smpl @first @first+162+!i var var1.ls 1 1 beta_1 beta_2 beta_3 ' make system for the VAR-GARCH var1.makesystem(n=sys1) ' estimate the VAR-GARCH BEKK sys1.arch @diagbekk C(indef) arch(1,diag) garch(1,diag) ' make the model for forecasts sys1.makemodel(mod1) smpl @first+163+!i @first+163+!i ' perform the forecasts mod1.solve(d=d) smpl @all series beta_1 = beta_1_0 series beta_2 = beta_2_0 series beta_3 = beta_3_0 'delete the auxiliar betas delete beta_1_0 delete beta_2_0 delete beta_3_0 next
Re: Forecasting Multivariative GARCH - Using Code
Posted: Sat Aug 18, 2018 9:47 am
by pvestia
Please someone can help me? It would be extremely appreciated
Re: Forecasting mean equation of a Multivariate VAR-GARCH: Using code
Posted: Mon Aug 20, 2018 8:26 am
by pvestia
Please no one?! I just want to know with this procedure I'm doing is a good way to just simulate the errors using the BEKK-GARCH(1,1) model in isolation, then feed those in to solving the mean model, which is a VAR(1).
Please, your feedback is extremely appreciated.
