one step in loop summation not executed
Posted: Thu Jun 07, 2018 7:44 pm
by frankhespeler
I execute the following command line six times (in a loop).
{%replacename2_2} = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
Summation works only for the first 5 steps, but not the sixth. When I subsequently compute an additional series as
series ztestsumm = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
summation suddenly works. Is there an obvious reason for this behavior?
many thanks
Re: one step in loop summation not executed
Posted: Fri Jun 08, 2018 7:01 am
We'd need more context.
Posted: Fri Jun 08, 2018 9:56 am
by frankhespeler
Not sure whether this can help: i included the entire monsterloop, in which the command line is embedded, and highlighted the command line I sent earlier in red. Again in essence: the loop would add six times new information for the replacement series {%replacename2_2}, which is originally declared and set to series containing exclusively zeros, but it does so only five times. Once I construct a new series doing the addition one time more the result is correct => the last step of the loop is not executed!
for %indicator {indicatoracroloop}
sectoracro = @wnotin(@wnotin(sectoracro, %sectoracroaggexc),"SECAGG OFI OFI2 OFINCLB OFINCLN")
%varname1 = "ind_1_" + %indicator + "_*"
%varname2 = "ind_2_" + %indicator + "_*"
%varname4 = "ind_4_" + %indicator + "_*"
%varname5 = "ind_5_" + %indicator + "_*"
%objectlist1 = @wlookup(%varname1)
%objectlist2= @wlookup(%varname2)
%objectlist4= @wlookup(%varname4)
%objectlist5= @wlookup(%varname5)
!objectnum = @wcount(%objectlist1)
for !z = 1 to !objectnum
%replacename1 =@wdelim(@wleft(@wdelim(@word(%objectlist1,!z),"_"," "),6)," ","_")
%replacename1a =@word(%objectlist1,!z)
%replacename2 = @wmid(@wdelim(%replacename1,"_"," "),4)
%replacename2 = "nfp " + %replacename2
%replacename2 = @wdelim(%replacename2 ," ","_") + "*"
!namenum=@wcount(%replacename2)
if !namenum > 1 then
%replacename3 = @wright(@wlookup(%replacename2),1)
else
%replacename3 = @wright(@wlookup(%replacename2),!namenum)
endif
%indfreq = @lower(@wright(@wdelim(%replacename1,"_"," "),1))
for %country {countryacro}
%exclname = @lower(%indicator)+ "_" + @lower(%country) + "_string"
%country1 = "_" + %country + "_"
if @isobject(%exclname)=1 then 'and {%exclname}.@type= "String"
string sectoracroloc = @wnotin(sectoracro,%exclname)
if @instr(%replacename1, %country1) > 0 and @instr(%replacename3, %country1) > 0 then
for %sector {sectoracroloc}
%sector1 = "_" + %sector + "_"
if @instr(%replacename1, %sector1) > 0 and @instr(%replacename3, %sector1) > 0 then 'or @isobject(%replacename3) )= 1
%existtestname = "denominator_" + %country + "_" + %indfreq
if @isobject(%existtestname) = 0 then 'series creation
series denominator_{%country}_{%indfreq} = 0
endif
denominator_{%country}_{%indfreq} = denominator_{%country}_{%indfreq} + @recode(@isna({%replacename3})=1,0, {%replacename3}) ' @recode({%replacename3}<>0, {%replacename3},NA) 'eliminate 0 entries in NFP series
endif
endif
delete sectoracroloc
else
for %sector {sectoracro}
endif
endif
endif
endif
else
endif
%replacename2 =@wdelim(@wleft(@wdelim(@word(%objectlist2,!z),"_"," "),6)," ","_")
%replacename2a =@word(%objectlist2,!z)
%replacename4 =@wdelim(@wleft(@wdelim(@word(%objectlist4,!z),"_"," "),6)," ","_")
%replacename4a =@word(%objectlist4,!z)
%replacename5 =@wdelim(@wleft(@wdelim(@word(%objectlist5,!z),"_"," "),6)," ","_")
%replacename5a =@word(%objectlist5,!z)
%exclname = @lower(%indicator) + "_" + @lower(%country) + "_string"
string sectoracroloc = @wnotin(sectoracro, %exclname)
if @instr(%replacename1, %sector1) > 0 and @instr(%replacename3, %sector1) > 0 and @instr(%replacename1a, %country1) > 0 then 'or @isobject(%replacename3) )= 1
%existtestname = @wdelim(@wleft(@wdelim(@replace(%replacename1,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename1_1 = @wdelim(@wleft(@wdelim(@replace(%replacename1,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename2_1 = @wdelim(@wleft(@wdelim(@replace(%replacename2,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename4_1 = @wdelim(@wleft(@wdelim(@replace(%replacename4,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename5_1 = @wdelim(@wleft(@wdelim(@replace(%replacename5,%sector1,"_secagg_",1),"_"," "),6)," ","_") + "_calc"
series {%replacename1_1} =0
series {%replacename2_1} =0
series {%replacename4_1} =0
series {%replacename5_1} =0
else
endif
series weight_{%indicator}_{%sector}_{%country}_{%indfreq} ={%replacename3}/@recode(denominator_{%country}_{%indfreq}<>0, denominator_{%country}_{%indfreq},NA)
{%replacename1_1} = {%replacename1_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq}) * @recode(@isna( {%replacename1a})=1,0, {%replacename1a})
{%replacename2_1} = {%replacename2_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq})* @recode(@isna( {%replacename2a})=1,0, {%replacename2a})
{%replacename4_1} = {%replacename4_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq})* @recode(@isna( {%replacename4a})=1,0, {%replacename4a})
{%replacename5_1} = {%replacename5_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq})* @recode(@isna( {%replacename5a})=1,0, {%replacename5a})
endif
endif
else
series {%replacename1_1} = 0
series {%replacename2_1} = 0
series {%replacename4_1} = 0
series {%replacename5_1} = 0
else
endif
{%replacename4_1} = {%replacename4_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq}) * @recode(@isna( {%replacename4a})=1,0, {%replacename4a})
{%replacename5_1} = {%replacename5_1} + @recode(@isna(weight_{%indicator}_{%sector}_{%country}_{%indfreq})=1,0,weight_{%indicator}_{%sector}_{%country}_{%indfreq}) * @recode(@isna( {%replacename5a})=1,0, {%replacename5a})
endif
endif
endif
delete denominator*
'''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' aggregation across countries
sectoracro = @wunion(sectoracro,"SECAGG OFI OFI2 OFINCLB OFINCLN")
countryacro = @wnotin(countryacro,"GL countryagg")
if %indicator = "LEV2" then
string zzztest = @wlookup("ind_2_lev2_*")
endif
if @instr(%replacename1, %sector1) > 0 then
if @instr(%replacename1, %country1) > 0 then
%existtestname = "denominatorcorr_" + %sector
series denominatorcorr_{%sector} = 0
endif
%namecheckEU = @replace(%replacename1,@upper(%country1),"_EU_",1) + "*" '@wleft(@wdelim(@replace(%replacename1,%country2,"_EU",1),"_"," "),3) + "*"
%namecheckEA = @replace(%replacename1,@upper(%country1),"_EA_",1) + "*" '@wleft(@wdelim(@replace(%replacename1,%country2,"_EA",1),"_"," "),3) + "*"
%namecheckNA = @replace(%replacename1,@upper(%country1),"_NA_",1) + "*" '@wleft(@wdelim(@replace(%replacename1,%country2,"_NA",1),"_"," "),3) + "*"
%namecheckEU = @wkeep(%objectlist1,@upper(%namecheckEU))
%namecheckEA = @wkeep(%objectlist1,@upper(%namecheckEA))
%namecheckNA = @wkeep(%objectlist1,@upper(%namecheckNA))
if @wcount(%namecheckNA)=0 then
if @wcount(%namecheckEU)=0 then
if @wcount(%namecheckEA)=0 then
%regionreplace = "nat"
!prestest = @wfindnc("EU EA NA",%country) ' to be updated if country coverage changes
if !prestest = 0 then
denominatorcorr_{%sector} = denominatorcorr_{%sector} + @recode(@isna( gdpdata\weights_{%regionreplace}_{%country})=1,0, gdpdata\weights_{%regionreplace}_{%country}) 'series value update
else
endif
else
%regionreplace = "EA"
!prestest = @wfindnc("AT BE DE EU FI FR IE IT LUX NL NA",%country) ' to be updated if country coverage changes
else
endif
endif
else
%regionreplace = "EU"
!prestest = @wfindnc("AT BE DE EA FI FR IE IT LUX NL UK PL NA",%country) ' to be updated if country coverage changes
denominatorcorr_{%sector} = denominatorcorr_{%sector} +@recode(@isna( gdpdata\weights_{%regionreplace}_{%country})=1,0, gdpdata\weights_{%regionreplace}_{%country}) 'series value update
else
endif
else
%regionreplace = "EUEA"
!prestest = @wfindnc("AT BE DE FI FR IE IT LUX NL UK PL NA",%country) ' to be updated if country coverage changes
else
endif
if %comparetemp = "IND_2_LEV2_SECAGG" then
series ztestdenom = denominatorcorr_{%sector}
endif
endif
endif
else
if @wcount(%namecheckEU) =0 then
if %namecheckEA =0 then
%regionreplace = "NA"
!prestest = @wfindnc("US CA EU EA",%country) ' to be updated if country coverage changes
else
endif
else
%regionreplace = "EANA"
!prestest = @wfindnc("US CA AT BE DE EU FI FR IE IT LUX NL",%country) ' to be updated if country coverage changes
else
endif
endif
else
if @wcount(%namecheckEA) =0 then
%regionreplace = "EUNA"
!prestest = @wfindnc("US CA AT BE DE FI FR IE IT LUX NL UK PL EA",%country) ' to be updated if country coverage changes
else
endif
else
%regionreplace = "EUEANA"
!prestest = @wfindnc("US CA AT BE DE FI FR IE IT LUX NL UK PL",%country) ' to be updated if country coverage changes
else
endif
endif
endif
endif
endif
endif
%existtestname = @wdelim(@wleft(@wdelim(@replace(%replacename1,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename1_2 = @wdelim(@wleft(@wdelim(@replace(%replacename1,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename2_2 = @wdelim(@wleft(@wdelim(@replace(%replacename2,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename4_2 = @wdelim(@wleft(@wdelim(@replace(%replacename4,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
%replacename5_2 = @wdelim(@wleft(@wdelim(@replace(%replacename5,%country1,"_countryagg_",1),"_"," "),6)," ","_") + "_calc"
series {%replacename1_2} =0
series {%replacename2_2} =0
series {%replacename4_2} =0
series {%replacename5_2} =0
endif
%comparetemp= @upper(@wdelim(@wleft(@wdelim(%replacename2,"_"," "),5)," ","_"))
if %comparetemp = "IND_2_LEV2_SECAGG_US" then
string zstring = %namecheckEU
string zstring1 = %namecheckEA
string zstring2 = %namecheckNA
endif
if @wcount(%namecheckNA) =0 then
series weight_{%indicator}_{%country}_{%sector} =gdpdata\weights_{%regionreplace}_{%country}/@recode(denominatorcorr_{%sector}<>0, denominatorcorr_{%sector},NA)
{%replacename1_2} = {%replacename1_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename1a})=1,0, {%replacename1a}) 'series value update
{%replacename4_2} = {%replacename4_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename4a})=1,0, {%replacename4a})
{%replacename5_2} = {%replacename5_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename5a})=1,0, {%replacename5a})
else
endif
else
!prestest = @wfindnc("AT BE DE EU FI FR IE IT LU NL NA",%country) ' to be updated if country coverage changes
{%replacename4_2} = {%replacename4_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode (@isna({%replacename4a})=1,0, {%replacename4a})
else
endif
endif
else
!prestest = @wfindnc("AT BE DE EA FI FR IE IT LU NL UK PL NA",%country) ' to be updated if country coverage changes
series weight_{%indicator}_{%country}_{%sector} = gdpdata\weights_{%regionreplace}_{%country}/@recode(denominatorcorr_{%sector}<>0, denominatorcorr_{%sector},NA)
else
endif
else
series {%replacename1_2} = {%replacename1_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename1a})=1,0, {%replacename1a}) 'series value update
series {%replacename2_2} = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
series {%replacename4_2} = {%replacename4_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename4a})=1,0, {%replacename4a})
series {%replacename5_2} = {%replacename5_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename5a})=1,0, {%replacename5a})
' if %comparetemp = "IND_2_LEV2_SECAGG_US" then
' zscalar = zscalar +1
' {%replacename2_2} = {%replacename2_2} + @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
' series ztestsumm = {%replacename2_2} '+ @recode(@isna(weight_{%indicator}_{%country}_{%sector})=1,0,weight_{%indicator}_{%country}_{%sector}) * @recode(@isna({%replacename2a})=1,0, {%replacename2a})
' scalar zscalar2 = !prestest
' string ztestword = %country
' endif
else
endif
endif
endif
else
else
endif
else
else
endif
endif
else
else
endif
else
else
endif
endif
endif
endif
endif
endif
delete denominator_corr*
countryacro = @wunion(countryacro, "GL COUNTRYAGG")
Posted: Fri Jun 08, 2018 10:04 am
Yeah, that's a bit much to debug by site. You're going to have to debug manually.
I cases like this I like to create a table object outside of the loop, then record all the variables inside the loop so that I can see what is going on.
Something like:
table temp temp(1,1) = "!a" temp(1,2) = "%j" temp(1,3) = "!i" !r=2 for %j {%mylist} for !i= 1 to 10 'stuff here involving %j, !i and another variable !a temp(!r,1) = !a temp(!r,2) = %j temp(!r,3) = !i !r=!r+1 next
Posted: Fri Jun 08, 2018 3:13 pm
by frankhespeler
Debugging gives me the strange results that I have after the sixth adding operation a nonzero value in the series %replacename2_2 when reporting it to a table, but a zero value in the graph of the actual series. i guess the variable does not date up the latest loop step? What can i do?
