How to extract the sample actually used for estimation in equations?
mamo
Postby mamo » Wed May 16, 2018 5:45 am
Dear Eviews team,
I am using Eviews 9 December 2016 built.
Is there an easy way to extract the sample actually used for estimation (i.e., after adjustments of missing values) in an equation object in a program?
The string provided by "equation.@smpl" would not do since it provides the sample which was in place when the estimation was called for; it does not account for the sample actually used after adjustment for missing values.
Best, mamo
Re: How to extract the sample actually used for estimation in equations?
Postby EViews Gareth » Wed May 16, 2018 5:57 am
Make residuals then set the sample to if resid<>na
mamo
Postby mamo » Thu May 17, 2018 1:30 am
Many thanks,
this works if you just want to set the sample accordingly, but it is not quite the solution if you are after getting the exact definition of the adjusted sample for further processing and usage in a program. (Note that calling @pagesmpl after "sample if resid<>na" would not provide the wanted result.)
One approach would be freezing and subsequently parsing the equation results view, but this is cumbersome (and prone to errors).
I'd therefore suggest that the Eviews teams adds a string like "equation.@smpladj" to the equation object in future updates of Eviews
Best
Postby EViews Gareth » Thu May 17, 2018 6:43 am
It isn’t quite that simple though. What if the equation estimates on data where every other observation is NA? There is no way to represent the actual sample.
