SVAR
Posted: Fri Apr 20, 2018 7:01 pm
A - am using eviews 10 and am doing SVAR with 5 variables and I want to make sure that am doing the right process:
1 - select VAR
2 - use proc and estimate structural factorization and I impose restriction on B to be diagonal and on A I impose three more restriction on the lower triangular since I only to impose restriction on the contemporaneous restriction and no restriction on lags
3 - for IR I choose structural decomposition
4 - VD also I select structural decomposition
B- how I can change the analytic in IR from 68% error band?
C- how I can do the same process in A by using syntax?
thanks
1 - select VAR
thanks
