Estimation of Taylor rule with smoothing parameter
Posted: Sun Apr 15, 2018 7:23 am
by res
I am interested in the estimation of Taylor rule with interest rate smoothing, like in the attached picture.
I have done only simple regressions, but I have never done regression with rho(smoothing parameter).
Can anyone suggest how it can be done in EViews?
Thank you in advance!
Re: Estimation of Taylor rule with smoothing parameter
Posted: Sun Apr 15, 2018 7:47 am
You can specify a regression in EViews by writing out an equation using c(1), c(2), etc as names for the coefficients, as in
Posted: Sun Apr 15, 2018 9:43 am
by res
Thank you for your reply.
I now understand that I porbably need to do this regression with GMM method, I specified everything, but something is wrong as I get message singular matrix. How can I fix this?
Posted: Sun Apr 15, 2018 9:53 am
I think that the problem is that you have both included c and clicked include a constant in the instrument list.
Posted: Sun Apr 15, 2018 10:00 am
by res
I deleted c from the instrumental list, but it still does not work and I get message singular matrix. Maybe you have other ideas?
I am so desperate, don't know how to solve this problem.
Posted: Sun Apr 15, 2018 10:55 am
What you've done looks right. Since your model is linear, you might try the TSLS command and see if that works. Also, before you run GMM set c=0.
Posted: Sun Apr 15, 2018 11:11 am
by res
What do you mean by set c=0? How can I do that? Will it impact results?
Posted: Sun Apr 15, 2018 11:13 am
Type c=0 into the command line before estimating an equation. This resets the starting values of the coefficients. Not likely to matter, but there's a chance.
Posted: Sun Apr 15, 2018 11:30 am
by res
It still does not work.
Tried to do the same way as in this pdf
http://coin.wne.uw.edu.pl/~lgoczek/pdf/ ... trics5.pdf, but no results.
The problem only disappears when I remove a constant term c(2) from the regression, but I cannot use such result, I think.
Anyway, thank you for your help and time, I really appreciate that!
